Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Antifreeze out of the exhaust
Post new topic    Yesterday's Tractors Forum Index -> John Deere
ffdfireman18
PostPosted: Sat Oct 13, 2012 6:04 am    Post subject: Antifreeze out of the exhaust Reply to specific post Reply with quote
I finally got my 45 A running pretty good. I plowed 2 acres with it and took the disc to it. The problem I"m having is it sat for probably two months now. I shut the gas off and ran it out when I parked it. I went to start it yesterday and it spit out what looks to be water out of the exhaust. Quite a bit all over the hood and dripping on the floor. After further inspection it had some antifreeze in it. I checked the coolant level and it wasn"t really low. About 1-2 inches down from the very top of the filler neck. Anything to worry about? Bad head or head gasket? Any help or comments are appreciated.
Husker44A
PostPosted: Sat Oct 13, 2012 7:37 am    Post subject: Re: Antifreeze out of the exhaust Reply to specific post Reply with quote
Cracked head or head gasket
DONMYEIL
PostPosted: Sat Oct 13, 2012 12:49 pm    Post subject: Re: Antifreeze out of the exhaust Reply to specific post Reply with quote
Might try retorque the head.,if its fresh overhaul. Sounds like seepege thru the gasket. Check oil for antifreeze there.
jd b puller
PostPosted: Sat Oct 13, 2012 7:11 pm    Post subject: Re: Antifreeze out of the exhaust Reply to specific post Reply with quote
The manifold studs go into water too.
JDseller
PostPosted: Sat Oct 13, 2012 11:36 pm    Post subject: Re: Antifreeze out of the exhaust Reply to specific post Reply with quote
My first JD tractor was JD "G". It would leak anti-freeze into the cylinders if it set more than a few weeks. I had the engine completely apart and check out. Nothing could be found wrong. I owned the tractor for thirty years it did it until I sold it and the new owner says it still does it.
My solution was if I was going to be using it in a month or so I just opened the pet cocks when I went to start it. It would blow the water out the pet cocks. For over the winter I just removed the spark plugs and filled the cylinders with diesel fuel. That would keep it from rusting the cylinder walls. I then just spun it over a few time and re-installed the spark plugs.
Dandy Dave
PostPosted: Sun Oct 14, 2012 12:16 am    Post subject: Re: Antifreeze out of the exhaust Reply to specific post Reply with quote
Did these still have the tubes for the push rods in 45? I had to replace the steel ones with the brass replacments in both my 39 A and my 37 BO. Also, I've seen hairline cracks in the heads where the coolant flows around the intake valve chamber. The last series of A's no longer had the tubes.
Mike M
PostPosted: Sun Oct 14, 2012 4:20 am    Post subject: Re: Antifreeze out of the exhaust Reply to specific post Reply with quote
I'd retorque the head then premix some bars leak and dump it in and then go plow again. This stopped my B from weeping thru the gasket.
