Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
OT CRF70F motorcycle carb.
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Tom N MS
PostPosted: Sun Oct 14, 2012 8:27 am    Post subject: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
New one is identical to the old one but inside the throttle slide hole there is an insert that will not let the slide go in the last 1/2 inch. can this be removed? Anybody know a good cycle forum that will respond?? Thanks
old
PostPosted: Sun Oct 14, 2012 8:43 am    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Can not be 100% sure on this since it has been a while since I messed with motorcycle carbs but. Make sure you have the slide turned just right. Many of those had a slot that, that insert runs in and is not lined up it will keep the slide from dropping all the way
Tom N MS
PostPosted: Sun Oct 14, 2012 9:05 am    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Old, yes that is correct..had it all lined up -wouldn"t go so looked at the old carb and it does not have the insert--looks like brass sleeve about 1/8 thick and 3/8-1/2 tall--keeping the sl;ide from going in that same distance.
old
PostPosted: Sun Oct 14, 2012 9:16 am    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Guess there is no easy way to remove that inset?? With out messing up the carb that is
JMOR
PostPosted: Sun Oct 14, 2012 11:30 am    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
I might be asking why it is there? what purpose?, etc. rather than how can I remove it. Pretty fair chance that is did NOT go like this" hey fellas, we got some extra money to burn....see if you can think of something useless that we can throw into one of our carbs."
ZANE
PostPosted: Sun Oct 14, 2012 1:07 pm    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Tom, I don't know why that would be in the throat where the slide goes but I do know how to give some relief that might let you pull the extra piece out of the slide throat.
Take a small propane torch and gently heat the outside around that insert and the aluminum will swell considerably and loosen up the insert maybe.
Maybe drop in a couple of ice cubes while heating to help the inside keep cool.
On old motorcycle carburetors that the slide has stuck from sitting up a long time this trick works every time.
Zane
Tom N MS
PostPosted: Sun Oct 14, 2012 1:22 pm    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Simply will not work with the slide--u get a new main needle etc but u use your old slide--should be a 2 bolt deal--I"VE CHANGEDM BECUILT A FEW OVER THE YEARS...WHATEVER THEIR REASON STOPS THE SHOW TILL i CAN MAKE SENSE OUT OF IT.
TheOldHokie
PostPosted: Sun Oct 14, 2012 2:00 pm    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
TOM N MS wrote:
(quoted from post at 17:22:23 10/14/12) Simply will not work with the slide--u get a new main needle etc but u use your old slide--should be a 2 bolt deal--I"VE CHANGEDM BECUILT A FEW OVER THE YEARS...WHATEVER THEIR REASON STOPS THE SHOW TILL i CAN MAKE SENSE OUT OF IT.
Manufacturer's help desk is usually a lot better than YT for things like this.
TOH
Tom N MS
PostPosted: Sun Oct 14, 2012 4:10 pm    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Yea, and u know u will wait forever and if u lucky u get a person who knows less english than a 2 yr old...I figured it out..Thanks
old
PostPosted: Sun Oct 14, 2012 4:16 pm    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
So G what did you do to it?? I have to rescue the boy this afternoon when his Yamaha 750 would not run as it should, clogged fuel filters by the way
Tom N MS
PostPosted: Sun Oct 14, 2012 5:06 pm    Post subject: Re: OT CRF70F motorcycle carb. Reply to specific post Reply with quote
Was a case of dummyism and can"t see..they actually had dropped the new slide in the slide throat..turned it over and bumped it and it fell out...glad you got John going again..gotta get mine(1100 Shadow Spirit) to the shop..Bomagas got to it when I didn"t ride it much last summer--not running good at all..hadn"t ridden it any this summer..
