| Author |
Message |
rick2 in ohio Regular
Posted: Sun Oct 14, 2012 3:06 pm Post subject: 8ft disc leaves humps |
i noticed last spring my 8ft 3-point massey disc leaves humps about 4 ft wide about 2 foot apart as i go acroos the field would a harrow help keep everything level.
RICK |
| Back to top |
dmiller Long Time User
Posted: Sun Oct 14, 2012 3:26 pm Post subject: Re: 8ft disc leaves humps |
is it a single gang or double gang? Has it been leveled if it is a double gang? |
| Back to top |
paul Tractor Guru
Posted: Sun Oct 14, 2012 6:47 pm Post subject: Re: 8ft disc leaves humps |
Disks will do that, adjusting the disk properly (more art than science, some models you can't get perfect....) will do more for you than a harrow.
Describe the disk better, as the other person asks, single or double gang, and so on.
--->Paul |
| Back to top |
mazemeister Regular
Posted: Mon Oct 15, 2012 3:24 am Post subject: Re: 8ft disc leaves humps |
leveling front to back, rankness adjustments, uneven wear, ground speed, depth, gang spacing, proper overlap one pass to the next...
a few places to start  |
| Back to top |
OH - 961 Regular
Joined: 07 Sep 2011 Posts: 155 Location: Central Ohio
Posted: Mon Oct 15, 2012 2:33 pm Post subject: Re: 8ft disc leaves humps |
I'm not sure from your description where the humps are. Do you mean that it leaves a ridge behind the disc in the middle of the pass?
If it is leaving a low area or a ridge behind the disc, the angle of the rear gang needs to be adjusted, or maybe both front and rear gangs so they equal out.
Myron |
| Back to top |
rick165 Regular
Posted: Thu Oct 18, 2012 5:11 am Post subject: Re: 8ft disc leaves humps |
sorry for not getting back to all of you i been very busy at work.is is a double gang and it leaves the valley in the center down the middle of the disc.
RICK |
| Back to top |
OH - 961 Regular
Posted: Thu Oct 18, 2012 1:12 pm Post subject: Re: 8ft disc leaves humps |
Sounds like you need to angle the rear gang a bit more to throw more of the dirt back toward the center.
Also check level front-to-back to see if the front gang is digging in deeper and throwing more dirt than the rear gang.
Are the discs on the rear worn down more than the front discs or are they pretty much equal? Just some things to look for.
Myron |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13145 Location: Coyote Flats,Tx
Posted: Fri Oct 19, 2012 3:09 am Post subject: Re: 8ft disc leaves humps |
| rick165 wrote: | (quoted from post at 09:11:22 10/18/12) sorry for not getting back to all of you i been very busy at work.is is a double gang and it leaves the valley in the center down the middle of the disc.
RICK |
Need to lower rear gangs(change level fore to aft) some to throw more soil or possibly increase ground speed. Also increasing the angle of rear gangs could help fill the valley. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
