| Author |
Message |
DON TX Tractor Expert
Joined: 09 Aug 2001 Posts: 2255 Location: Midlothian, Tx
Posted: Tue Oct 16, 2012 7:18 pm Post subject: Filter spring size? |
After installing the pan, I found that there's barely enuff room to get a socket on some of the bolts and barely enuff room to get a open end wrench on to tighten the rest more than a 1/4 turn at a time. 2 of the holes are just far enuff off the bolts won't start. Got to find a way to get them started w/o removing and reaming the holes out. The cast iron is thicker, of course, and even tho they ground the pan to make room, they didn't grind enough for most. Found no filter when I dropped the pan and no spring. Anyone have the specs on the spring?
DON TX |
| Back to top |
Posted: Wed Oct 17, 2012 12:34 pm Post subject: Re: Filter spring size? |
The filter I have has the wire bale handle. Does the handle go to the bottom or top? The parts drawing shows felt washer(s) that go on top of the filter under the spring. Are these necessary? I've never changed 1 of these and the original filter was missing along with all the piddly stuff. Can someone explain what I need to do?
DON TX |
| Back to top |
kesiladi New User
Posted: Wed Oct 17, 2012 3:02 pm Post subject: Re: Filter spring size? |
Longer screws ? |
| Back to top |
trac Long Time User
Posted: Wed Oct 17, 2012 3:21 pm Post subject: Re: Filter spring size? |
Hi Don the handle goes to the bottom so it can easily be pulled out as far as the washers i would put them in. |
| Back to top |
2tractors Long Time User
Posted: Wed Oct 17, 2012 3:31 pm Post subject: Re: Filter spring size? |
Been a while since I've been in a 20 but do remember posting the order once in the archives, I had to cut somre rungs off an old bed spring until it held the "basket" flush against the oil pan. Make sure the pipe has the center hole clear. Install the spring and basket then the felt washer then tie it with wire so it doesn't fall down then install the pan, reach inside remove wire and install filter then the round cover with gasket |
| Back to top |
Posted: Wed Oct 17, 2012 3:39 pm Post subject: Re: Filter spring size? |
After looking in the archives there is also a "pan" so its spring,pan,basket,washer filter. |
| Back to top |
Posted: Wed Oct 17, 2012 7:14 pm Post subject: Re: Filter spring size? |
Ok, you just informed me there is something else missing. The "basket". Great. What do I do about that. Chances of finding a used one won't be very likely since it sounds like they damage easily. Looked in YT, Stieners and no new part available. I wonder how important it is if you change oil on a timely basis you won't have to worry about gobs or junk building up enuff to bother the filter. I'll have to think about this.
DON TX |
| Back to top |
Posted: Wed Oct 17, 2012 7:15 pm Post subject: Re: Filter spring size? |
Thanks, now I have to find some washers.
DON TX |
| Back to top |
Posted: Thu Oct 18, 2012 4:08 am Post subject: Re: Filter spring size? |
The basket is something similar in shape as the "pan" and is a screen mesh like a colander or strainer.I don't think its all that necessary.I've never found a big glob stuck between the screen. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
