| Author |
Message |
FletchVa New User
Posted: Wed Oct 17, 2012 2:42 pm Post subject: Water level in Radiator |
For some reason the water level in my radiator keeps getting low. not real low.I think. I check it before I drive the tractor(1951 8n)and make sure the level is just above the tube openings. Where oh where did the water go?? |
| Back to top |
pconnie Regular
Posted: Wed Oct 17, 2012 3:34 pm Post subject: Re: Water level in Radiator |
possibly out the exhaust..head gasket..check the cylinder compression ..spark plugs can be steamed cleaned..surely you checked the oil..gets milky with water |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50396 Location: Lake of the Ozarks area of MO
Posted: Wed Oct 17, 2012 4:14 pm Post subject: Re: Water level in Radiator |
Could be a number of problems. I'll start at the cheap and work on to the oh no stuff. #1 small leak at one of the hose connections. #2 a pin hole in a hose. #3 a water pump heading south on you #4 a small hole in the radiator and #5 the head gasket has a leak |
| Back to top |
JCinKY Regular
Posted: Wed Oct 17, 2012 4:27 pm Post subject: Re: Water level in Radiator |
| old wrote: | | (quoted from post at 17:14:19 10/17/12) Could be a number of problems. I'll start at the cheap and work on to the oh no stuff. #1 small leak at one of the hose connections. #2 a pin hole in a hose. #3 a water pump heading south on you #4 a small hole in the radiator and #5 the head gasket has a leak |
I'll add #6...internal crack in block. Check oil for dirty chocolate milk look as said earlier. Water level goes down and oil level goes up may mean crack in the water jacket. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
