Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
2N Stiff Right Brake
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
Colin King
PostPosted: Wed Oct 17, 2012 5:20 pm    Post subject: 2N Stiff Right Brake Reply to specific post Reply with quote
The right brake pedal on the '47 2N I'm working on requires a good deal of pressure to push down to get the pedal to travel. Once pushed down, the pedal wants to stay there unless you pull it up with your toe. Pulling it up also requires an unusual amount of force. When the pedal travels, you can hear a squeaking noise and feel drag somewhere in the mechanism. What should I be looking for to fix this problem?
Thanks!
Colin, MN
HCooke
PostPosted: Wed Oct 17, 2012 6:03 pm    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
I would suspect the bushing where the brake activation shaft goes thru the backing plate. Heat, PB Blaster, repeated for several days will loosen it up.
Colin King
PostPosted: Wed Oct 17, 2012 6:18 pm    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
Great! I'll give that a try and report back. Thank you!
Colin
Charnerl
PostPosted: Wed Oct 17, 2012 7:18 pm    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
Pull the tire and hub. You can then work the brake and see whats happening and correct.
Ultradog MN
PostPosted: Thu Oct 18, 2012 2:47 am    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
I think Harold pegged it. They get dry and full of crud in there.
If you do have to take it apart to clean/lube it, consider taking both sides apart and switching the shafts from right to left. I did that on a 2N I had and eliminated about 40 years worth of wear where the clutch pedal rides on the shaft. There was still some wear in the clutch pedal itself but it tightened up that pivot a Lot.
Colin King
PostPosted: Thu Oct 18, 2012 12:28 pm    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
Thanks, Jerry!
Colin
Colin King
PostPosted: Thu Oct 18, 2012 12:29 pm    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
Hopefully I can solve the problem without going through the hassle of removing that rear tire. But if not, then it's gotta come off for sure.
Colin
tracman
PostPosted: Fri Oct 19, 2012 2:09 pm    Post subject: Re: 2N Stiff Right Brake Reply to specific post Reply with quote
I had the same problem. I did pull the wheel off and axel out and cleaned the brakes but still could not get the shaft to move in the bushing. I put it back on the the tractor and worked it by hand every day and spraying oil and penetrating oil on the shaft where it goes thru the bushing. It did work loose. I think it worked better on the tractor because the shaft was held staright by the bearing in the diff. housing.
