Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
pto shaft question
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
gbs
PostPosted: Sat Oct 20, 2012 5:53 pm    Post subject: pto shaft question Reply to specific post Reply with quote
we have several trail type pto driven pieces of equipment,problem i'm running into is when i turn with the pto engaged if i turn a little to short the shafts will shutter with the exception of one peanut combine it has a short shaft like the haybine does, the rest are long shafts,all them have the u-joints lined up parallel except the peanut combine i mentioned before it's joints are 90 degrees apart it can be turned about 70 degrees either direction before the hitch binds it never shutters turning ,should the rest be 90 degrees off also ???the one's that shutter have u-joint yokes that are long and wide to allow for being run at an angle.
Don-Wi
PostPosted: Sat Oct 20, 2012 6:34 pm    Post subject: Re: pto shaft question Reply to specific post Reply with quote
The PTO shafts need to be in phase, so that means the yoke on both ends of the shaft need to be lined up. Is your drawbar set right? How tight of a turn are you making?
Donovan from Wisconsin
Brendon-KS
PostPosted: Sun Oct 21, 2012 2:54 am    Post subject: Re: pto shaft question Reply to specific post Reply with quote
A u-joint essentially has a "gear ratio" that follows a sine wave pattern when running at an angle. In other words, the output speed goes up and down relative to the input speed. An "equal angle" driveline always has two u-joints that run at the same angle and are in phase with each other. This results in the speed ratios canceling themselves out and the output speed then equals the input speed of the system. (A CV joint works exactly the same way except it two u-joints bundled into a single package.) However, if your driveline has only one u-joint that bends when you turn the input speed going into the implement is pulsing up and down. This is what causes the chatter.
Leroy
PostPosted: Sun Oct 21, 2012 4:59 am    Post subject: Re: pto shaft question Reply to specific post Reply with quote
Are the ones making the noise a 2 joint shaft? And the others a 3 joint shaft? Everything that I had with the 2 joint shaft had that problem, but not with the 3 joint shaft . Location of the second joint makes if you have the problem. And the 2 joint machines are generaly the cheaper designed and cheaper sold machines.
Nebraska Cowman
PostPosted: Sun Oct 21, 2012 8:52 am    Post subject: Re: pto shaft question Reply to specific post Reply with quote
Which in simple terms a layman can understand the pivot point (hitch pin) needs to be centered between the two joints, correct?
Brendon-KS
PostPosted: Sun Oct 21, 2012 9:05 am    Post subject: Re: pto shaft question Reply to specific post Reply with quote
You're right. If your hitch pin is centered between two u-joints then you should be able to have a chatter-free system. If you have one u-joint right at the tractor and one way back on the implement then you can expect vibration during turns.
John B.
PostPosted: Sun Oct 21, 2012 3:16 pm    Post subject: Re: pto shaft question Reply to specific post Reply with quote
Yes the ujoints have to be phased with each other and are you hooking up to the middle of your drawbar or to one side?
I have seen an exception on a Case ground driven hay rake where the drive shaft from the drive wheel to the gearbox was 90° out of phase. The angle on the ujoints always stayed the same and when turning it over by hand you could feel it bind.
gbs
PostPosted: Sun Oct 21, 2012 6:27 pm    Post subject: Re: pto shaft question Reply to specific post Reply with quote
2 of the peanut combines have 5' long shafts with u-joints at each end,the haybine, potato digger and other combine have short shafts close to 3' with u-joints at each end all are center pull,all have the yokes lined parallel to each other except the combine with the short shaft it's yokes are 90 degrees apart, it's the only one that doesn't shutter when turned more than 10 degrees ,the short shaft machines shafts are about centered on the draw bar pivot point,all are pulled from the 3 point hitch to enable the machines to be raised and lowered which also can add to the problem ,the haybine doesn't shutter as bad when turned to the left the rest of them it don't matter they do it either direction
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
