| Author |
Message |
Mark1248 New User
Posted: Sun Oct 21, 2012 7:56 am Post subject: D17 hand clutch |
Does anyone have suggestions on how to make the hand clutch hold from slipping on a D17 that I have a small block Chevy in? It will hold up to ths rpms but not the power. If not, how do I delete the hand clutch-my last choice as I want all eight gear choices. Thanks, Mark. |
| Back to top |
CTucker Regular
Posted: Mon Oct 22, 2012 10:20 am Post subject: Re: D17 hand clutch |
Does it "snap" tight into both high and low side? If not, it need work. |
| Back to top |
rogerdoger-plowboy Regular
Posted: Mon Oct 22, 2012 4:57 pm Post subject: Re: D17 hand clutch |
Did you put the V8 in the tractor? or did you buy it like that? If you put it in yourself, how difficult was it to do? |
| Back to top |
Ron in Mn. Regular
Posted: Wed Oct 24, 2012 7:24 pm Post subject: Re: D17 hand clutch |
You can adjust the hand clutch,remove the cover on right side were oil lines go on into it. There are three places on this clutch were shims can be moved!! from frt.&rear of this unit to the center.you loosen two bolts ,remove a .015 ths.from frt.& rear & install in center ,tighten bolts , move on to other shims do same thing.should snap over frim.IF not let me know.RON |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
