| Author |
Message |
john in the highlands Regular
Joined: 05 Jun 2012 Posts: 35 Location: The Highlands of Ontario, Canada
Posted: Sun Oct 21, 2012 8:35 am Post subject: mf 35 postive grounded gas gauge |
I'm getting around to fixing up the old gal. I've got a new postive grounded gas gauge, seems only to take 3 volts to make it read full (using 2 AA batteries. However the new sending unit and my old one, no matter what the gas level, in my 12 volt system sends way to much voltage. Since the TSC catelogue only offers only one postive grounded gauge, do I have the wrong mf 35 sending unit? Am I missing some voltage reducer? I've been playing with the sending unit, There's more voltage resistance the lower the gas level, so that part's working to indicate the gas level change. |
| Back to top |
Tony in Mass. Tractor Guru
Posted: Sun Oct 21, 2012 9:30 am Post subject: Re: mf 35 postive grounded gas gauge |
Look for the wiring diagrams in the FENA website, sounds like it needs a reduce don't it? |
| Back to top |
35 MF Guest
Posted: Sun Oct 21, 2012 11:20 am Post subject: Re: mf 35 postive grounded gas gauge |
Why did you get a positive ground gauge? I believe all the 35's were negative ground. |
| Back to top |
Posted: Mon Oct 22, 2012 10:11 am Post subject: Re: mf 35 postive grounded gas gauge |
mine's a positive ground. Apparently tractors and trucks earlier on were positive grounded to reduce the chance of shorting out causing an explosion. Also, copper wires originally weren't coated so they corroded quicker if the ground was negative. |
| Back to top |
Posted: Mon Oct 22, 2012 10:14 am Post subject: Re: mf 35 postive grounded gas gauge |
Thanks, Ill try that |
| Back to top |
35 MF Guest
Posted: Mon Oct 22, 2012 7:00 pm Post subject: Re: mf 35 postive grounded gas gauge |
Some tractors that were 6 volt were positive ground like an 8N but I'm pretty sure a 12 volt MF 35 is negative ground. I know there are people on this forum that would know for sure. |
| Back to top |
Chip812 Long Time User
Posted: Tue Oct 23, 2012 6:32 am Post subject: Re: mf 35 postive grounded gas gauge |
Mine is negative ground. 1961 MF35 Deluxe |
| Back to top |
Posted: Sun Nov 04, 2012 8:03 am Post subject: Re: mf 35 postive grounded gas gauge |
I finally found a postive grounded gas gauge from a&i, It says 12v on it. I used a circuit tester on it (2-AA batteries, 3 volts), my fuel sender is 30-250ohms, when the sender is at it's highest resistance using the 3 volts, the gauge reads empty and then reads full with 30ohms resistance. it reads full all the time in both with the 12 volt tractor battery. But, the gauge only works in both cases , when the ground is negative.
U.K.mf 35 tractors were 12 postive grounded, why is my U.S. tractor postive grounded when the rest are negative? It's a pain in the butt! I'm trying to get my supplier to replace the gauge, it's got to be deffective! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
