VF4 VH4 cyls interchange
Duner Wi
PostPosted: Sat Jan 12, 2013 7:52 pm    Post subject: VF4 VH4 cyls interchange Reply to specific post Reply with quote
Has anybody ever put cylinders and manifolds from a VG4 even fire onto a VF4 odd fire.
Looks like it might work but would like to know for sure.
JOB
PostPosted: Sun Jan 13, 2013 2:02 am    Post subject: Re: VF4 VH4 cyls interchange Reply to specific post Reply with quote
I would think that parts from a VG4 would not interchange with a VF4. Your subject says VF4 VH4, so you may just have a typo. I could see VF4 and VH4 interchanging, but not certain.
Duner Wi
PostPosted: Sun Jan 13, 2013 6:59 am    Post subject: Re: VF4 VH4 cyls interchange Reply to specific post Reply with quote
You are correct. It is VH4 cyls to a VF4.
Anybody know anything?
Tramway Guy
PostPosted: Tue Jan 15, 2013 9:26 am    Post subject: Re: VF4 VH4 cyls interchange Reply to specific post Reply with quote
The late VED/VFD crankcase is the same as VH4D. I think there are differences between the heads and manifolds, so if you changed all that stuff, it might work. You would have a VH4D with an odd-firing crankshaft.
greygoat
PostPosted: Wed Jan 16, 2013 9:24 am    Post subject: Re: VF4 VH4 cyls interchange Reply to specific post Reply with quote
Cylinder blocks have different part numbers in
the master parts book, for: VE4, VF4, VH4.
Further research is needed, but I don"t feel
well enough to do it right now!
Duner Wi
PostPosted: Wed Jan 16, 2013 7:23 pm    Post subject: Re: VF4 VH4 cyls interchange Reply to specific post Reply with quote
The cylinders would have different #s because of the manifolding to block was different. VH4 has horseshoe exhaust manifold. But I was thinking someone might know if I changed VH4 cylinders and
manifolding onto a VF4 it might work. Sounds plausible but don't know. I have downloaded most of V4 parts lists. Thanks
Duner Wi
PostPosted: Wed Jan 16, 2013 7:29 pm    Post subject: Re: VF4 VH4 cyls interchange Reply to specific post Reply with quote
I have a good VF4 block and crank. Cylinders not so good.
I also have VH4 with bad crank that cylinders might clean up with a hone. Working on a plan. Thanks.
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
