Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TO20 rear axle seals
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
Al Barclay
PostPosted: Mon Oct 22, 2012 5:11 am    Post subject: TO20 rear axle seals Reply to specific post Reply with quote
I am replacing the rear axle oil seals on a TO20 and I found someone had installed what looks like an aftermarked inner oil seal pressed into the bearing retainer housing on the left axle,it,s a cup like affair with a seal pressed into it and then it was pressed into the bearing housing against the bearing race,the seal then rides on the axle. I found they are listed in my All States Ag Parts catalog,has any one had any experience using these seals and will they cause the bearing to not get enough lubrication,thanks for any input,Al
trac
PostPosted: Mon Oct 22, 2012 5:20 am    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
Is it the sure seal? I believe they also worked on the Ford 9N
Jason S.
PostPosted: Mon Oct 22, 2012 7:57 am    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
Sounds like a sure seal to me. When installing them you have to pack the bearing full of wheel bearing grease,because the bearing will no longer get lubricated by the oil that slings off of the differential.I think the part number for them is SS92
samn40
PostPosted: Mon Oct 22, 2012 1:39 pm    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
Sure are Sure Seals! If fitted correctly then you need go no further as they save a lot of time and expense.
Sam
Bruce(OR)
PostPosted: Mon Oct 22, 2012 5:50 pm    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
And the 2N but not the 8N.
Short fiber wheel bearing grease as is found in use on drum brake equipped cars.
PackardV8
PostPosted: Mon Oct 22, 2012 5:57 pm    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
The Sure Seals are great. Have them on my TO-20. However, if the OEM OUTER seal is bad then any grease packed into the bearing will leak out. So outer seal must be in good condition, sure seal or no sure seal. No???
John(UK)
PostPosted: Tue Oct 23, 2012 6:50 am    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
You need to pack the bearing with HMP grease every 12 months to avoid it running dry. You could fit a greaser like the later tractors which would save taking apart each time. Take care setting the axle-end float, it needs to be set correctly...John(UK)...fergusontractors@hotmail.com
PackardV8
PostPosted: Tue Oct 23, 2012 7:23 am    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
Assuming that the outer seal is in good condition and the SureSeal is used, then it is not clear to me how the bearing could ever run dry any faster than the front wheel bearings of an automobile or lite truck could ever run dry. At least not in such a short time period as one year. Automobiles and lite truck have a similar seal to the HF outer seal and just a dust cap. DOn't have to repak those every year.
PackardV8
PostPosted: Tue Oct 23, 2012 7:38 am    Post subject: Re: TO20 rear axle seals Reply to specific post Reply with quote
Bearing retainer puller pics. Works on TO-20. Maybe others too. Cheap easy fast to make. Replace the OUTER seal and use the Sure Seals and get on with life. It works. Rock'N Roll
