| Author |
Message |
RobP New User
Posted: Mon Oct 22, 2012 10:10 am Post subject: 8n hydraulic lift |
I have a question about my 1949 8n front mount distributer,hydraulic system.I bought tractor and noticed when lifting arms go up they shutter.Like its hesitating.System does not bleed down and will hold load. Drained fluid out and was very dirty with water,mud.Put in kerosene and drove around,turn pto and raised up and down several times,Drained again got more dirt.Took inspection plates off and sprayed parts cleaner on system and tried to get most of the sludge out. Could system just be plugged from dirt??I'd like to know whats causing the shuttering when lifting??Thanks Rob. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50428 Location: Lake of the Ozarks area of MO
Posted: Mon Oct 22, 2012 10:22 am Post subject: Re: 8n hydraulic lift |
Could be a number of things. Could be as simple as an adjustment needing to be made or a cam follower pin that is worn etc. The I-T FO-4 manual has a good bit on trouble shoot for such things |
| Back to top |
JMOR Tractor Guru
Posted: Mon Oct 22, 2012 10:26 am Post subject: Re: 8n hydraulic lift |
| RobP wrote: | | (quoted from post at 14:10:29 10/22/12) I have a question about my 1949 8n front mount distributer,hydraulic system.I bought tractor and noticed when lifting arms go up they shutter.Like its hesitating.System does not bleed down and will hold load. Drained fluid out and was very dirty with water,mud.Put in kerosene and drove around,turn pto and raised up and down several times,Drained again got more dirt.Took inspection plates off and sprayed parts cleaner on system and tried to get most of the sludge out. Could system just be plugged from dirt??I'd like to know whats causing the shuttering when lifting??Thanks Rob. | Pump has four cylinders, so if shudder is nice and periodic, like an engine missing on one cylinder, it may be bad valve(s) on one of the four cylinders. |
| Back to top |
Bruce (VA) Tractor Guru
Joined: 24 Feb 2003 Posts: 11266 Location: Old Church VA
Posted: Mon Oct 22, 2012 10:29 am Post subject: Re: 8n hydraulic lift |
" Put in kerosene and drove around,turn pto and raised up and down several times,Drained again got more dirt.Took inspection plates off and sprayed parts cleaner on system and tried to get most of the sludge out. "
Not only did you waste your time trying to clean it like that, you could have harmed the pump & the bearings in the rear end & transmission. Kerosine does not have sufficient lubricating properties for the pump, rear end & transmission; they all share the same sump.
When the N lift is jerky coming up it means that one or more of the four pump cylinders is not pumping. It can be caused by broken springs in the pump chambers or a broken Scotch yoke in the pump that the pistons are attached to. Either one means the pump will need to be removed from the tractor to fix it.
And when you pull the pump, clean it out.
With all of the fluid drained out, block the front wheels & get the rear wheels up at least a foot. (you'll see why soon enough) Remove the 4 bolts holding the PTO shaft in & pull it to the rear & out of the tractor. Loosen all of the bolts. Remove all but 2 corner bolts. Then, carefully remove them. If you are lucky, the pump will drop free (and dump a pint or so of hydraulic fluid down your sleeves). If not, wrestle it free. The pump has 'ears' that fit into the housing; wiggle it a bit & it will drop free. If you have the rear tires a foot or more off of the ground, you will have enough arm room to hold the pump & lower it at the same time. Put it on your work bench & remove the safety valve (p/n 638) and the control arm lever (p/n 643) which will allow you to remove the intake & exhaust valves (p/n’s 640 & 698) Drop all of it in a bucket of diesel (or mineral spirits) or your parts washer & let it soak overnight. Once it has a good soaking, get it on the bench & start blowing it out w/ compressed air. Run cleaning fluid into the hydraulic discharge near the test port & make sure you get a good flow out the small hole in the side of the pump were the control valve fits. I don't see much need to pull it down any further just to clean it. (in order to see why it's jerky coming up, you will need to pull it down further than this) But, I always replace the safety valve (p/n 638, about $25) Reinstalling the pump is harder than pulling it out because you have a gasket to worry about. (no sealer on the gasket) And, you will probably need a helper to guide the control rod into the pump rocker shaft unless you’ve done this 6 or 7 times before!
While you have the PTO shaft out, it would be a good time to replace the seal on it. It's got two spring clamps around it. Take your needle nose pliers & remove the one in the front. Then, hang the shaft & bearing housing in your vice & tap the butt end of the shaft; the bearing cap will come off (and the shaft will land on your foot). Then, remove the other spring clip from the other side of the bearing. At this point, remember that you never bought a seal driver & go get a BF socket & drive the seal out. If you have the new style seal, the white side goes out. (open side to the oil) Put some grease on it.
Contrary to conventional wisdom, not a lot of water gets in the oil from the shifter boot. Of course, if it's bad, replace it, but you get water from the draft control spring & the dipstick. But, most water is just a byproduct of the heating/cooling cycle of the oil.
You’ll need a pump gasket, safety valve, inspection plate gasket(s), PTO seal, PTO gasket, gasket sealer & 5 gallons of fluid to do all of the above.
50 Tips
| Back to top |
RobP New User
Posted: Tue Oct 23, 2012 5:42 am Post subject: Re: 8n hydraulic lift |
Ok thanks that is my next thing to do is pull the pump.I won't do the kerosene trick again!!!!Thanks Bruce!!! Rob. |
| Back to top |
clarencebramlett Guest
Posted: Wed Oct 24, 2012 1:09 pm Post subject: Re: 8n hydraulic lift |
i have 1952 8n the hydraulic works good going up when letting it down and it gets less haft down it falls the rest away down what should i do plus i have 1947 or48 2n or 9n trans. and rear end oil been draind what type oil to put back in thanks for your help have a bles day |
| Back to top |
JMOR Tractor Guru
Posted: Wed Oct 24, 2012 2:22 pm Post subject: Re: 8n hydraulic lift |
| clarencebramlett wrote: | | (quoted from post at 17:09:12 10/24/12) i have 1952 8n the hydraulic works good going up when letting it down and it gets less haft down it falls the rest away down what should i do plus i have 1947 or48 2n or 9n trans. and rear end oil been draind what type oil to put back in thanks for your help have a bles day | When you observe this "drop", are you in position control mode or draft control mode? |
| Back to top |
Kevin Cooper Guest
Posted: Wed Oct 24, 2012 3:09 pm Post subject: Re: 8n hydraulic lift |
I removed my hydraulic pump to replace the gasket.I now have no lift.Would this be because the control rod is not inserted in the pump rocker shaft correctly. The PTO turns but no lift. 48 8n front mount |
| Back to top |
JMOR Tractor Guru
Posted: Wed Oct 24, 2012 3:25 pm Post subject: Re: 8n hydraulic lift |
| Kevin Cooper wrote: | | (quoted from post at 19:09:54 10/24/12) I removed my hydraulic pump to replace the gasket.I now have no lift.Would this be because the control rod is not inserted in the pump rocker shaft correctly. The PTO turns but no lift. 48 8n front mount | You are making me guess that you mean control arm as opposed to rockshaft. See picture. If control arm not connected to pump, the it is not going to work!
| Back to top |
mbramble Regular
Joined: 05 Nov 2011 Posts: 253 Location: Cantonment, FL
Posted: Wed Oct 24, 2012 5:00 pm Post subject: Re: 8n hydraulic lift |
| clarencebramlett wrote: | | (quoted from post at 14:09:12 10/24/12) i have 1952 8n the hydraulic works good going up when letting it down and it gets less haft down it falls the rest away down what should i do plus i have 1947 or48 2n or 9n trans. and rear end oil been draind what type oil to put back in thanks for your help have a bles day |
Clarence -
Please drop me an e-mail when you get a chance. We may have more in common than just a 52 8N.
E-mail is mike@bramblett.com
Thanks,
Mike |
| Back to top |
clarence bramlett Guest
Posted: Fri Oct 26, 2012 3:21 pm Post subject: Re: 8n hydraulic lift |
mike iam having trouble getting e-mail out on my computer send me e- mail so i can see if i can receive it thanks |
| Back to top |
mbramble Regular
Posted: Fri Oct 26, 2012 3:43 pm Post subject: Re: 8n hydraulic lift |
"mike iam having trouble getting e-mail out on my computer send me e- mail so i can see if i can receive it thanks"
Done...
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
