Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1948 Ferguson TO-20 Electrical System
Post new topic    Yesterday's Tractors Forum Index -> Restoration and Repair Tips
Randy Roberson
PostPosted: Tue Oct 23, 2012 7:52 am    Post subject: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
Hi, I'm finally getting my tractor running again, now that the weather has cooled off. The electrical system was converted to 12V negative ground some years ago, and it is about 1/2 missing. There is a solenoid switch mounted on the battery tray, and a ballast resistor in the circuit to the ignition coil. Rather that spend time restoring it to positive ground, etc. I am just trying to get her running for now.I have bought and installed the reproduction switch which is activated by the shift lever, and I plan to use it in place of the old starter button, along with the solenoid, so at least I will have the neutral safety feature this provides.
What is the correct polarity to install the ignition coil for negative ground: neg to dist, or pos to dist? I think neg to dist, is this correct? It is a 12 Volt coil.
I also am trying to connect the ballast resistor bypass on the solenoid for more ignition voltage during cranking: is this as simple as it looks (connect this terminal on the solenoid to the coil side of the ballast resistor)?
Also, I will probably do away with the key switch (On-Off) as it is broken, and use a toggle switch. Any problem, functionally speaking? I might include a pilot lamp as a reminder to leave the switch off. Depends on if I get her running pretty soon, etc. Thanks for all the advice!
old
PostPosted: Tue Oct 23, 2012 8:16 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
The points ground the coil so when it does it fires the plugs so what ever side of the battery ground that is in turn the same for the coil. So yes + on the coil goes to the distributor
Randy Roberson
PostPosted: Tue Oct 23, 2012 8:18 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
Ok, thanks, I should have put this in the Ferguson section; sorry.
Jerry/MT
PostPosted: Tue Oct 23, 2012 8:44 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
The primary wire running to the distributor from the coil should have the same sign as the battery ground. In your case 12V (-), that means the primary wire to the distributor from the coil should be on the coil(-) terminal
old
PostPosted: Tue Oct 23, 2012 9:04 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
I did sort of say things back wards. When the points open is when the spark fires off but other wise the coil is grounded. As for which forum as long as you get your answers what does it matter
JMOR
PostPosted: Tue Oct 23, 2012 10:12 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
Randy Roberson wrote:
(quoted from post at 11:52:59 10/23/12) Hi, I'm finally getting my tractor running again, now that the weather has cooled off. The electrical system was converted to 12V negative ground some years ago, and it is about 1/2 missing. There is a solenoid switch mounted on the battery tray, and a ballast resistor in the circuit to the ignition coil. Rather that spend time restoring it to positive ground, etc. I am just trying to get her running for now.I have bought and installed the reproduction switch which is activated by the shift lever, and I plan to use it in place of the old starter button, along with the solenoid, so at least I will have the neutral safety feature this provides.
" is this as simple as it looks (connect this terminal on the solenoid to the coil side of the ballast resistor)? " What is "this terminal"? How many terminals are on your solenoid?
Randy Roberson
PostPosted: Tue Oct 23, 2012 10:20 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
Solenoid has two high-current (large) terminal posts: one from the positive side of the battery, and the other from the solenoid to the starter. It has three small posts: one goes to the key switch, then to the ballast resistor, to power the ignition; one activates the solenoid by giving it 12V from the pos battery post, and usually the third one is a ballast resistor bypass. It becomes energized when cranking (when the solenoid is energized) and sends the full 12V to the ignition system, bypassing the ballast resistor, so the ignition has more power for starting.
Looks like it was not connected and all the ignition was going through the ballast resistor all the time, so it may not be necessary. You used to see this setup on Ford products.
Randy Roberson
PostPosted: Tue Oct 23, 2012 10:21 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
I may have it wrong, I'll look at it when I get home and see how wrong.
JMOR
PostPosted: Tue Oct 23, 2012 10:33 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
(quoted from post at 14:21:40 10/23/12) I may have it wrong, I'll look at it when I get home and see how wrong.
Don't see many of the 5 terminal solenoids, but if so, one of the 3 likely needs ground, probably from neutral start switch, but maybe not on your Fergy, since it originally did not have a solenoid, as I recall?
Randy Roberson
PostPosted: Wed Oct 24, 2012 4:22 am    Post subject: Re: 1948 Ferguson TO-20 Electrical System Reply to specific post Reply with quote
My tractor;s solenoid has two large terminals adn two small. One of the small terminals should connect to the "crank" switch adn will activate the solenoid and starter when it gets 12V. The other small terminal becomes energized with 12V when the solenoid is activated (i.e while cranking) and should be wired around the resistor in the power circuit to the coil; purpose is to provide a temporary hotter spark while cranking. the solenoid grounds via the body and contact with th etractor frame where it is attached.
I think I have it now.
Thanks, everyone,
RR
