| Author |
Message |
Jswintex Guest
Posted: Wed Oct 24, 2012 11:29 am Post subject: Kuhn GMD 800 Length Alteration |
I have a Kuhn GMD 800 HD II, 10 ft cut. At the end of this summer, on the end of the bar the bolts at the last top hat worked loose and cracked the tip of the bar. Could I cut the end of the bar, weld/seal the end and use the Kuhn as a 9 ft mower? Has anyone heard or seen this done? Thanks |
| Back to top |
WGWKy2 Guest
Posted: Wed Oct 24, 2012 1:51 pm Post subject: Re: Kuhn GMD 800 Length Alteration |
I do not see why not. I once added a foot to a cycle mower and it worked fine. |
| Back to top |
RickB Tractor Guru
Posted: Wed Oct 24, 2012 3:53 pm Post subject: Re: Kuhn GMD 800 Length Alteration |
The outermost knife hat must rotate counterclockwise as viewed from the top, otherwise you are wasting your time. |
| Back to top |
cannonball Regular
Posted: Thu Oct 25, 2012 3:38 am Post subject: Re: Kuhn GMD 800 Length Alteration |
on a nine ft the first 2 disc turn clockwise....then ccw and cw to the end one, as said below, the last one is ccw, can you do it..I would say no.... |
| Back to top |
bg/mo Regular
Posted: Thu Oct 25, 2012 4:26 pm Post subject: Re: Kuhn GMD 800 Length Alteration |
this guy is working on a disc mower, not a sickel |
| Back to top |
RodinNS Tractor Guru
Posted: Tue Oct 30, 2012 7:55 am Post subject: Re: Kuhn GMD 800 Length Alteration |
Why try to reinvent the wheel? As rick noted... The outer disc must turn counterclockwise to pull hay from the edge of the cut. Doesn't work otherwise. Weld up the cracks... Very carefully... And move on.
Rod |
| Back to top |
sideconsole4020guy Regular
Posted: Tue Oct 30, 2012 5:22 pm Post subject: Re: Kuhn GMD 800 Length Alteration |
Could just buy a new bar, as if the welding doesnt hold and the oil leaks out then you ruin all the gears and bearings |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
