Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
OT/Refrigerator compressor clicks, buzzes, clicks
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
markiz41
PostPosted: Wed Oct 24, 2012 3:07 pm    Post subject: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
An 11 year old fridge started acting up. Compressor clicked on, buzzed for 10-15 sec and clicked off. I measured the current draw when it was on and it was a whopping 11 amps! (it's rated for 7amps) So I replace the starter/overload relay, thinking it was faulty - same thing is happening. Checked for continuity between compressor plug prongs and the body - no shorts. Is the compressor toasted? Anything else I can check to make sure? Thanks..
Billy Shafer
PostPosted: Wed Oct 24, 2012 3:38 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Mine was doing the same thing. Compressor was locked up.
Greenday
PostPosted: Wed Oct 24, 2012 4:01 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Bad compressor
wisbaker
PostPosted: Wed Oct 24, 2012 4:30 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Locked rotor condition on your compressor. The first click is the relay to turn it on, it's locked so it draws inrush (11 amps) until the circuit breaker kicks out, 2nd click when the circuit breaker/overload protection cools the cycle starts all over again
GarryinNC
PostPosted: Wed Oct 24, 2012 4:40 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Have seen a couple that did that over the years that was caused by a bad start capacitor. $10-$15 dollar item. Not all compressors have them though.
Charles (in GA)
I'll add a 4th to that, locked up compressor, had exact same thing happen to my shop fridge. Tilt it over in the back of the truck and head for the scrap place, go to Lowes or HD and find a scratch and dent model.
Charles
Steve A W
PostPosted: Wed Oct 24, 2012 4:48 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
While it is buzzing, Give the compressor a hit with a hammer.
Sometimes it will un stick the comp.
Might buy You some time.
Good Luck.
Steve A W
markiz41
PostPosted: Wed Oct 24, 2012 5:01 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Not worth fixin' then? I see these compressors selling for around $300. New fridge will be at least $800. A skid row special will not work here, this is a kitchen unit.
David G
PostPosted: Wed Oct 24, 2012 5:30 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Could be a bad starting capacitor, otherwise motor is locked up.
George Marsh
PostPosted: Wed Oct 24, 2012 6:22 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Mark,
Could be anything from a bad compressor, coked condenser, bad start relay or bad capacitor. Not all ref compressors use a start capacitor.
Unplug and allow compressor to cool off. Make sure condenser isn't full of lint before you try to restart it. If it fails to restart try the following:
First thing I would do is remove start relay/or start cap. There are 3 terminals on compressor. Common, start and run. Measure the resistance from common to start and common to run. The exact resistance isn't important. Need to make sure wires aren't open. Will get a resistance of 10 ohms or less. There should be a diagram or marking someplace to determine C, R and S. Also check wires for shorts to ground, the metal of compressor.
Second, I would look for a capacitor. Many old ones didn't use start caps.
Third, If compressor didn't have a start cap, I would rig up a cord to connect power to common,C, and neutral to run ,R, winding.
Fourth, use an amprobe to measure current on common leg.
Fifth, Connect a jumper wire from run to start. I would use a short jumper with insulated alligator clips so they could be removed easily.
Plug in the power cord you made up and a second later remove jumper from start to run.
Compressor will then run on the power connected to common and run.
If compressor uses a capacitor you will need to connect it with a jumper between run and start and remove cap a second later too.
If you don't have a clue what I'm telling you, CALL A PROFESSIONAL OR GET A NEW REF.
The clicking sound you are hearing is the Klixon opening. You can google Klixon motor protector.
My dad was in the heating, air and ref business. So you could say, I grew up working on this stuff. If you don't feel comfortable with electricity, call someone.
George
M-MAN
PostPosted: Wed Oct 24, 2012 8:37 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Amp draw say's it's a locked rotor and there ain't no fixing that. A hammer might free it up but it will lock again. I woulden't replace the compressor in mine if it locked and I have all the equipment to do it with.
markiz41
PostPosted: Thu Oct 25, 2012 6:18 am    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
Thanks, all. Time to shop for a new one.
George Marsh
PostPosted: Thu Oct 25, 2012 1:43 pm    Post subject: Re: OT/Refrigerator compressor clicks, buzzes, clicks Reply to specific post Reply with quote
If you could put off buying a new ref, I'm sure you will see a lot of deals real soon. Black Friday if not sooner.
