| Author |
Message |
lemroy Regular
Posted: Wed Oct 24, 2012 6:06 pm Post subject: run away throttle on a Ford 601 diesel |
On my 601 Ford diesel the throttle is wide open when first cranked. After a while it will slow down. How do I fix it? Roy |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Wed Oct 24, 2012 8:11 pm Post subject: Re: run away throttle on a Ford 601 diesel |
Replace the "plastic" governor ring inside the pump. That obviously requires pump disassembly. |
| Back to top |
Larry NCKS Tractor Guru
Joined: 23 Dec 2001 Posts: 3711 Location: Washington, KS/Lincoln, NE
Posted: Wed Oct 24, 2012 10:38 pm Post subject: Re: run away throttle on a Ford 601 diesel |
x2 and while you're at it, clean all the debris from the old one out the return line and other places. Put new seals on the drive shaft too. pump kits can be had for 30 bucks on eBay and perhaps not much more than that at your l;ocal diesel shop.
NOTE: This is not a job you should tackle unless you know what you're doing! |
| Back to top |
john in la Tractor Guru
Joined: 28 Mar 2004 Posts: 5889 Location: Bedico, La.
Posted: Thu Oct 25, 2012 4:50 am Post subject: Re: run away throttle on a Ford 601 diesel |
That is why shops can charge hundreds of dollars to install this $30 part. It is not a hard job but requires knowledge of the system. |
| Back to top |
lemroy Regular
Posted: Thu Oct 25, 2012 4:54 pm Post subject: Re: run away throttle on a Ford 601 diesel |
Thanks for your help. Roy |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
