| Author |
Message |
IA Roy Regular
Posted: Wed Oct 24, 2012 8:53 pm Post subject: Air hose reel rotary union |
I have a home built hose reel. I used a 1/4" air quick coupling as the rotary union to allow the reel to rotate while providing air to the hose. The coupling doesn't last very long until it starts leaking. Does anyone know of a source to replace this with something that was intended to do this job? This time, I greased the inside of the coupling. I have no idea if it will help.
Thanks in advance! |
| Back to top |
MarkB_MI Tractor Guru
Posted: Thu Oct 25, 2012 1:18 am Post subject: Re: Air hose reel rotary union |
Googling "air hose reel swivel" gets you a lot of options. It looks like they start around 50 bucks. |
| Back to top |
greygoat Tractor Expert
Posted: Thu Oct 25, 2012 7:33 am Post subject: Re: Air hose reel rotary union |
AEROQUIP makes high quality ones..Quality does
not come cheap! |
| Back to top |
JMOR Tractor Guru
Posted: Thu Oct 25, 2012 11:39 am Post subject: Re: Air hose reel rotary union |
| IA Roy wrote: | (quoted from post at 00:53:38 10/25/12) I have a home built hose reel. I used a 1/4" air quick coupling as the rotary union to allow the reel to rotate while providing air to the hose. The coupling doesn't last very long until it starts leaking. Does anyone know of a source to replace this with something that was intended to do this job? This time, I greased the inside of the coupling. I have no idea if it will help.
Thanks in advance! | They are by no means heavy duty commercial quality, but you could buy the cheapest hand-crank hose reel from Harbor Freight/Tool and use the rotary joint........they will last awhile. $19.99 |
| Back to top |
S.C. Guest
Posted: Thu Oct 25, 2012 1:33 pm Post subject: Re: Air hose reel rotary union |
The hose reels we have at work have rotary unions that are repairable. There are only two o-rings to replace. Remove a snap ring and it's apart. |
| Back to top |
Loosehandle Regular
Posted: Thu Oct 25, 2012 4:07 pm Post subject: Re: Air hose reel rotary union |
Mcmastercar |
| Back to top |
IA Roy Regular
Posted: Fri Oct 26, 2012 10:13 am Post subject: Re: Air hose reel rotary union |
I guess I will continue using the $5 quick connect.
I did see that Blains had a reel with I think 50 foot of hose for around $40.
Thanks for the conversation. |
| Back to top |
Jon Hagen Tractor Expert
Posted: Fri Oct 26, 2012 10:25 am Post subject: Re: Air hose reel rotary union |
We have used the same setup (quick coupler as a rotary union + home made 100 ft reel) It still is leak free after 10+ years. It is an ARO brand and the parts are well coated with grease to lubricate them. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
