| Author |
Message |
Super Steve Regular
Joined: 27 Mar 2003 Posts: 347 Location: Ailsa Craig, ON, CA
Posted: Thu Oct 25, 2012 10:03 am Post subject: plowing question |
I'm plowing with a Ford 151 4x18 semi-mount plow and I can't seem to get it to leave the dead furrow clean. So on my next round its rough. It seems to be plowing decent to me except its not cleaning the last furrow. What am I doing wrong? |
| Back to top |
Badger08 Regular
Posted: Thu Oct 25, 2012 3:42 pm Post subject: Re: plowing question |
Try moving the rear coulter farther out, towards the furrow wall. Then if that does it, move the other's over as well. In our plow manual for our 4 bottom IH it says to do that on the rear coulter and once set do it on the rest. And in sod that you might have to do this. Corn ground not as big of a deal. |
| Back to top |
IaGary
Joined: 14 Jun 2007 Posts: 7257 Location: North Liberty Iowa
Posted: Thu Oct 25, 2012 3:44 pm Post subject: Re: plowing question |
Does the plow have disc colters?
They should be set so they slice one to two inches more than the plow bottom.
My colters are also set about 3 to 4 inches deep.
Without colters I don't ever see a furrow cutting clean
Gary |
| Back to top |
Super Steve Regular
Posted: Thu Oct 25, 2012 4:57 pm Post subject: Re: plowing question |
Ok thanx guys. It does have coulters and I've been playing with the back one but I was trying to set it close to the point. Ill move it out and see how it works |
| Back to top |
Super Steve Regular
Posted: Thu Oct 25, 2012 5:20 pm Post subject: Re: plowing question |
Gary, how much weight do you hang on the front of your 1086 when plowing? Does more weight make it ride any smoother? |
| Back to top |
Don-Wi Tractor Guru
Joined: 12 Aug 2002 Posts: 7658 Location: Hilbert, Wi
Posted: Thu Oct 25, 2012 5:47 pm Post subject: Re: plowing question |
Can't sya on his 1086, but on our Oliver 1855 we've got somewhere around 800 lbs on it. It just keeps the front end planted on the ground. If you're riding a bucking bronc, then you could use more weight up front.
Donovan from Wisconsin |
| Back to top |
Super Steve Regular
Posted: Thu Oct 25, 2012 6:10 pm Post subject: Re: plowing question |
That's what I figured. I went from a Deere to this
IH and it just doesn't ride as smooth. I've got 5
weights on the front but I guess ill have to hunt
some more down |
| Back to top |
IaGary
Posted: Thu Oct 25, 2012 6:23 pm Post subject: Re: plowing question |
Full set (10) but I"m pulling 6-16"s. Some of the bucking around may be from wheel slip. How is your rear weighted?
Air ride seat helps a lot.
Gary |
| Back to top |
Super Steve Regular
Posted: Thu Oct 25, 2012 8:41 pm Post subject: Re: plowing question |
Rear tires are loaded and I have the left dual on also. The rear inside tires are brand new. 5 weights on the front |
| Back to top |
Don-Wi Tractor Guru
Posted: Fri Oct 26, 2012 5:01 pm Post subject: Re: plowing question |
I gotta say the impression I get from driving around a 986 that we rent on occasion, is they're pretty light on the front end without weights. Atleast it seems lighter than our 1855 did before we added the starter weight, 1 stack and 4 slabs to it. The only time it rears up is when I snag a tree root close to the fence row.
| Back to top |
RodinNS Tractor Guru
Posted: Tue Oct 30, 2012 7:45 am Post subject: Re: plowing question |
Set the coulters so that they're leading in the cut that the shin wants so make... Then it should cut clean and reduce shin wear.
Rod |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
