| Author |
Message |
woodbutcher Long Time User
Posted: Thu Oct 25, 2012 12:43 pm Post subject: Stihl MS250 |
This is a 10 year-old saw that"s never been in the shop. It ran fine on Tuesday, and on Wednesday with the same tank of fuel, it would start with full choke, but then die when I opened the choke up. It has never needed choking after warming up, but now it seems to be starving for fuel. The air intake screen is clean as well as the fuel intake screen. I noticed that there is a black fuel line routed below the carb that looks like it is weather cracked. Does Stihl sell a kit to replace the fuel lines? The one on my saw is ribbed to make a sharp bend to attach to the carb.
Butch |
| Back to top |
2x4 Tractor Expert
Posted: Thu Oct 25, 2012 1:15 pm Post subject: Re: Stihl MS250 |
not really a kit but individual lines are available. Problem is obviously in the fuel system. If the muffler screen were clogged it wouldn't run at all. Check to see if the carb is loose, maybe leaking air past the carb gasket. |
| Back to top |
Ivan in Mich Regular
Posted: Thu Oct 25, 2012 1:56 pm Post subject: Re: Stihl MS250 |
Your fuel line is bad. Mine did the same thing and was told that the gas eats up the fuel line then it collapes when you try to use it. Mine just about fell apart when it was taken out |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Thu Oct 25, 2012 3:54 pm Post subject: Re: Stihl MS250 |
Either go to a dealer or on ebay. You can buy the gas line, it will likely cost $10-15.
Zach |
| Back to top |
Lou from Wi. Tractor Expert
Posted: Thu Oct 25, 2012 7:33 pm Post subject: Re: Stihl MS250 |
Ace Hardware handles some, we just bought some yesterday, had to change gas line on our lawn vacuum. LOU |
| Back to top |
dave2 Tractor Guru
Joined: 05 Feb 2006 Posts: 13551 Location: Kutzberg, Germany 1972 IHC 423 (German). 2.5 Liter 3cyl direct injection diesel 42HP
Posted: Fri Oct 26, 2012 1:00 am Post subject: Re: Stihl MS250 |
sounds like the fuel pickup line in the tank. While you're at it, check/change the filter on the end.
Have fun if you got stubby fingers  |
| Back to top |
Posted: Fri Oct 26, 2012 6:52 am Post subject: Re: Stihl MS250 |
Thanks for all the replies. I found the line on eBay, and it should arrive next Wednesday.
Butch |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
