| Author |
Message |
SPT Regular
Posted: Thu Oct 25, 2012 3:02 pm Post subject: Copper head gasket |
Having problems with sealing copper head gasket on 4.5 bore D 17 Allis, any suggestions? |
| Back to top |
Eric segaline New User
Posted: Thu Oct 25, 2012 4:04 pm Post subject: Re: Copper head gasket |
deck head and block and fire ring it |
| Back to top |
Ole Johnny Regular
Posted: Thu Oct 25, 2012 4:11 pm Post subject: Re: Copper head gasket |
When I used dead-soft copper head gaskets on my dragster, I had to O ring the block and head so they woudl work. Also it is necessary to use gray silicone to seal the water passages. If there is a composit head gasket for your application, I think that would be much better. |
| Back to top |
oliver80 Guest
Posted: Thu Oct 25, 2012 7:01 pm Post subject: Re: Copper head gasket |
I Always Spray Them With Copper Coat And Never Had Any Problems.My Sleeves Are Ringed Also |
| Back to top |
wi50 Regular
Posted: Fri Oct 26, 2012 5:08 am Post subject: Re: Copper head gasket |
I alawyse o-ring either the head or the block. Probably easiest to do the head as long as the block deck is flat.
I know there are guys useing composite gaskets on larger bores than that on the Allis and i'd think you can find fire rings and make one from a gasket |
| Back to top |
SPT Regular
Posted: Fri Oct 26, 2012 5:17 am Post subject: Re: Copper head gasket |
Thanks for the input. |
| Back to top |
MLPANKEY Tractor Expert
Posted: Fri Oct 26, 2012 7:11 am Post subject: Re: Copper head gasket |
| SPT wrote: | | (quoted from post at 06:17:39 10/26/12) Thanks for the input. | Stainless .024 wire place in groove on sleeve
| Back to top |
EP Regular
Posted: Fri Oct 26, 2012 4:02 pm Post subject: Re: Copper head gasket |
you can get an Isky O ring cutting tool from summit racing and cut a groove in the sleeve to put a piece of wire for your fire ring.I use stainless wire instead of copper wire.Tool is 300$ or so but works great.You will need to practice on an old sleeve or block a couple of times.good luck |
| Back to top |
Midnightrider Regular
Posted: Fri Oct 26, 2012 8:43 pm Post subject: Re: Copper head gasket |
| SPT wrote: | | (quoted from post at 00:02:32 10/26/12) Having problems with sealing copper head gasket on 4.5 bore D 17 Allis, any suggestions? |
Fire ring the block,Copper Coat the gasket and tighten her down. |
| Back to top |
Posted: Fri Oct 26, 2012 8:44 pm Post subject: Re: Copper head gasket |
| Back to top |
jim johnson Tractor Expert
Posted: Sat Oct 27, 2012 4:39 am Post subject: Re: Copper head gasket |
Lubbock gasket in Lubbock Tx. makes a gasket with a wire in it and I believe they guarantee it. You can ask Ken Foland about it because I think he was using one.
Jim |
| Back to top |
bassndeere Regular
Posted: Sat Nov 03, 2012 6:22 pm Post subject: Re: Copper head gasket |
Crank her up and get her warm, then torque head bolts/studs. Do this at least 3 times, increasing torque everytime to at least 175 lbs. Then but a load on her. PS. cold she will be over 200 lbs. |
| Back to top |
