| Author |
Message |
Brian Zimmerman New User
Posted: Thu Oct 25, 2012 4:23 pm Post subject: Mccomick deering no. 15 hay press |
Would like to know if anyone knows the dimensions of the wooden blocks for this hay press that goes between the bales |
| Back to top |
jbp Long Time User
Posted: Fri Oct 26, 2012 11:26 am Post subject: Re: Mccomick deering no. 15 hay press |
Went out and measured mine and surprisingly they only measure 15X15 inches. That is a factory block and the bale chamber is 16X18 inches. Joe |
| Back to top |
Posted: Fri Oct 26, 2012 11:47 am Post subject: Re: Mccomick deering no. 15 hay press |
What is the thickness of the wood and demension of the cut out notches |
| Back to top |
Ron W Regular
Posted: Fri Oct 26, 2012 8:50 pm Post subject: Re: Mccomick deering no. 15 hay press |
I have a 1918 M style baler; an old guy told me to make the blocks out of 1x4s or 1x6 pine. Never use plywood, oak or ash. Reason: if they get jammed, they will break if made out of pine, otherwise they may be too strong and something else will break--something more costlier. My blocks are three layers thick; front and back are horizontal, middle is verticle. Cut the horizontal edges on a 45 degree so that when they are placed 1/4 apart, there is a dovetail for you to feed the wire or twine through. |
| Back to top |
jbp Long Time User
Posted: Sat Oct 27, 2012 6:46 am Post subject: Re: Mccomick deering no. 15 hay press |
Block thickness is 2 3/4 inches
Bottom wire groove is 4 1/4 inches from bottom of block
Second wire groove is 11 3/4 inches from bottom of block
Wire groove is 1/4 inch wide at top and 3/4 inch at bottom.
Joe |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
