Help with old hydraulic motor and blower specs
Charlie
PostPosted: Thu Oct 25, 2012 4:59 pm    Post subject: Help with old hydraulic motor and blower specs Reply to specific post Reply with quote
I would be terribly grateful if anyone might have a moment to help me with either of the following two inquiries. I have a hydraulic motor, possibly an old one, identified on the nameplate as Haldex Hydraulics Corp., Rockford, Ill. It has two numbers: 040206 and then further below: 77101. I would love to know its specs and especially the size and type of the fitting that should screw into the threaded holes on the sides. It’s too small for ½” NPT and too big for 3/8” NPT, and I’m not even sure it’s NPT.
Second, the motor is mounted on a blower that was removed from some kind of machine. I’ve attached a picture of the blower-motor combination. Do you have any idea what the application for this kind of blower might have been. You can see the motor on the right side and a 4 inch air intake on the opposite side.
I've been thinking of rigging it up on my Bobcat 610 to blow leaves and debris.
jm.
PostPosted: Thu Oct 25, 2012 5:20 pm    Post subject: Re: Help with old hydraulic motor and blower specs Reply to specific post Reply with quote
Waste of time. Derbis blowers are in the range of 8 in wide by 48 in dia. That thing is just not going to blow many leaves. You Probably have fittings that use an o ring at the base.
