| Author |
Message |
Tom Bond Regular
Posted: Thu Oct 25, 2012 5:19 pm Post subject: Fuel Tank Sealer |
After I dry fit my replacement tank, just for the heck of it before I painted it, I poured in a gallon of gas in to check for leaks. Sure enough, there's one leak where it looks like someone put too long a mounting bolt through the cage nut on the rear support. Over time, It looks like it eroded away from the inside where it dimpled. Leaks a pretty steady drip. Will POR-15 stop something like this or is it time to start shopping for another 801 tank? Any suggestions or other products that might do the job? |
| Back to top |
WayneIA Long Time User
Posted: Thu Oct 25, 2012 5:44 pm Post subject: Re: Fuel Tank Sealer |
Sure will! I actually had a leak on a tank that the Por 15 driped out of. A little time of chasing Por 15 back and forth and it hasn't leak a bit since (5 years) |
| Back to top |
GlenIdaho Tractor Expert
Posted: Thu Oct 25, 2012 7:20 pm Post subject: Re: Fuel Tank Sealer |
Check the link below concerning POR 15 tank sealer. I used it in my take, no problems.
POR 15
| Back to top |
woodbutcher Long Time User
Posted: Fri Oct 26, 2012 3:09 am Post subject: Re: Fuel Tank Sealer |
Tom,
I used Red Kote on my 4000. It worked well.
Butch |
| Back to top |
Jim in Ma. Tractor Expert
Joined: 30 Jul 2007 Posts: 1865 Location: Newbury Ma. 01951
Posted: Fri Oct 26, 2012 4:23 am Post subject: Re: Fuel Tank Sealer |
I would just clean and solder it with an iron.
Easy 10 min fix. |
| Back to top |
Ed H.-OH Regular
Posted: Fri Oct 26, 2012 12:03 pm Post subject: Re: Fuel Tank Sealer |
Hello, Fiberglass resin works great, Don"t make any heat or sparks cleaning it.Buy it in any auto parts store. -ed |
| Back to top |
36 Coupe Tractor Guru
Posted: Fri Oct 26, 2012 3:48 pm Post subject: Re: Fuel Tank Sealer |
I favor solder with a electric iron.Get it clean and solder Use Nokorode solder paste. |
| Back to top |
Fuel leak Guest
Posted: Fri Oct 26, 2012 4:58 pm Post subject: Re: Fuel Tank Sealer |
You could use an epoxy like JB weld. Clean it really good and let it dry for 24 hours. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
