F2 Alternator
IHr190
PostPosted: Fri Oct 26, 2012 5:14 pm    Post subject: F2 Alternator Reply to specific post Reply with quote
I have an F2 gas with a bent alternator bracket. The
belt doesn't want to stay on. I've had this machine
for two years now, and had no problems last year
with the belt staying on. When you look down at it,
you can see that the alternator doesn't sit square
with the other pulley. Any ideas on why all of a
sudden? Thanks in advance. Rob
Kell
PostPosted: Fri Oct 26, 2012 6:52 pm    Post subject: Re: F2 Alternator Reply to specific post Reply with quote
Belt in good shape? Make sure there's no excessive play in the water pump pulley.
Allan in NE
PostPosted: Sat Oct 27, 2012 5:21 am    Post subject: Re: F2 Alternator Reply to specific post Reply with quote
On the bottom bracket, there is a small bushing; tiny "pipe" actually, which tightens and holds the alternator forward.
See if that thing has worn thru and allowing the back of the alternator to drop down a bit.
Allan
IHr190
PostPosted: Sat Oct 27, 2012 5:04 pm    Post subject: Re: F2 Alternator Reply to specific post Reply with quote
Allan, I don't even have that little pipe anymore! Just a 3/8 bolt. I will look at it tommorrow. Thanks again.
Dalet
PostPosted: Sun Oct 28, 2012 8:41 pm    Post subject: Re: F2 Alternator Reply to specific post Reply with quote
Line it up and it should work fine if tight.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
