Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
9N TRACTOR WON'T TURN OVER
Post new topic    Yesterday's Tractors Forum Index -> Ford 9N, 2N, 8N
TOM PAGEL
PostPosted: Sat Oct 27, 2012 10:23 am    Post subject: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
My 9n tractor, converted to 12v, many years ago, won't turn over. I've tried a different battery. And I have tried jumping it.Turning the key on shows a drop from zero on the amp meter. Putting a screw driver across the solenoid terminals does nothing. Tractor ran excellent until this issue developed. Any suggestions on what to look at/for next? Thanks
DON TX
PostPosted: Sat Oct 27, 2012 11:56 am    Post subject: Re: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
I just had to remove the starter and clean the mating surface for a good ground. Try that. I had same prob you did. HTH
DON TX
Dell (WA)
PostPosted: Sat Oct 27, 2012 12:05 pm    Post subject: Re: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
uh? Tom.........the 9N did NOT have a starter solenoid from the factory. Hard telling after 70-yrs what may have been re-wired. The 9N had a jiggle-pole operated starter safety switch from the bottom of the dash to the back of the dash. Surprizingly enuff, starter don't care 6V or 12V, positive or negative ground......still turns the correct direction only faster with 12V. Do NOT use wimpy ferrin maid starter cables. Use 'arry-chested 'merrican made ought (0) thick as yer thumb cable.
Do I haffta tell you to REPLACE yer starter motor cable???? .........respectfully, Dell
old
PostPosted: Sat Oct 27, 2012 12:21 pm    Post subject: Re: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
Take the battery cable off the solenoid battery side and try touching it to the starter stud. BE 1000% sure it is out of gear. You should get the engine to turn over by doing that plus you should get some sparking when you do that. No spark means a poor connection some place and or a burned up starter as in bad brushes or a poor starter ground
TOM PAGEL
PostPosted: Sat Oct 27, 2012 2:44 pm    Post subject: Re: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
Thank you. I'll let you know if that works.
TOM PAGEL
PostPosted: Sat Oct 27, 2012 2:47 pm    Post subject: Re: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
Thanks. I'll replace the cable. Thanks for the info.
TOM PAGEL
PostPosted: Sat Oct 27, 2012 2:48 pm    Post subject: Re: 9N TRACTOR WON'T TURN OVER Reply to specific post Reply with quote
Thanks. I'll give it a try.
