| Author |
Message |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5370 Location: SE Wisconsin
Posted: Sat Oct 27, 2012 5:41 pm Post subject: Converting overhead fuel barrel to pump style |
Has anyone converted an overhead fuel barrel to a pump setup? I would guess you need to weld feet on it and cut a hole in the top for the pump. Is there anything else to the job?
How do you cut and weld on the tank?
I was given these two overheads today. Don't be confused, there are two separtate setups pictured.
| Back to top |
Jim in MN Regular
Posted: Sat Oct 27, 2012 5:58 pm Post subject: Re: Converting overhead fuel barrel to pump style |
You could avoid welding on the tank by making the stands shorter. The fill cap should screw off. Install your pump there. Welding on tanks is risky business. |
| Back to top |
fixerupper Tractor Guru
Joined: 12 Oct 2003 Posts: 6909 Location: Albert City Iowa
Posted: Sat Oct 27, 2012 6:40 pm Post subject: Re: Converting overhead fuel barrel to pump style |
I agree with Jim. Welding isn't wise. Most fuel barrels have two 2" bungs on the top unless it's a real old one. If there is only one bung the pump will have to be lifted out for filling which is a little unhandy. I suppose you could put a tee on the fill bung, if there's only one, with a street el sticking out the side. Pump goes in from the top and you fill through the street el. It's not real conventional and you might have to get a longer suction pipe but you won't blow yourself up that way. Jim |
| Back to top |
Mo 1032D Regular
Posted: Sat Oct 27, 2012 8:08 pm Post subject: Re: Converting overhead fuel barrel to pump style |
Seen different ways to do what your planning, first you need to make sure you have no leaks in tanks. I made a fitting to pressurize tank to no more than 3 psi for 300 gal and 5psi for 500 gal. No since doing anything till you know tanks are good. As far as pumps I have seen them plumded into bottom bunge on tank, then braced with strap to top bunge as all you need to do is support pump. I would just shorten stands to your desired height. I have a few of my fuel customers that have done this, and havent had any problems. One of my customers put a post in the ground between his tanks and secured both pumps to it, worked out real nice that way. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
