| Author |
Message |
Dgunter Guest
Posted: Sat Oct 27, 2012 6:29 pm Post subject: White 2-70 fuel problem |
I'm having a fuel problem with a White 2-70 diesel. If you pull it hard it will slow down and die. Then after about 30 seconds it will restart. It only does it when running at high engine rpm. I replaced the fuel filter and cleaned the fuel bowl screen. Thanks for any help |
| Back to top |
Don-Wi Tractor Guru
Joined: 12 Aug 2002 Posts: 7604 Location: Hilbert, Wi
Posted: Sat Oct 27, 2012 6:32 pm Post subject: Re: White 2-70 fuel problem |
Is your fuel shut off working properly? Once in a while our Massey 285 will start running really weak, and then when I look down the fuel shut off is pulled out a little bit. Don't know how or why, but every now & then it gets me and this fall I drove it home ot change the fuel filters quick, but then Dad reminded me of the issue.
Donovan from Wisconsin |
| Back to top |
OLarry from MD Regular
Posted: Sun Oct 28, 2012 3:44 am Post subject: Re: White 2-70 fuel problem |
You got full flow from the tank? |
| Back to top |
rrlund Tractor Guru
Posted: Sun Oct 28, 2012 5:54 am Post subject: Re: White 2-70 fuel problem |
My Ford diesel pickup was doing that. The governor ring in the injector pump was bad. |
| Back to top |
gunter Guest
Posted: Sun Oct 28, 2012 9:43 am Post subject: Re: White 2-70 fuel problem |
I unhooked the line from the tank fuel ran out ok. RAN through the filter ok and to the pump. I haven't checked the shutoff cable, this one pushes in. I'll look at that. If that's ok I guess it's the pump. Thanks for the help |
| Back to top |
JWalker Regular
Posted: Sun Oct 28, 2012 5:12 pm Post subject: Re: White 2-70 fuel problem |
I know this sounds off base but check your fuel cap. I had a JD doing the same thing and the vent on the cap was stopped up. I replaced the cap and it has run fine for several years. |
| Back to top |
Neil Grant Guest
Posted: Thu Nov 01, 2012 6:44 am Post subject: Re: White 2-70 fuel problem |
Those Roosa pumps also need a good return flow or the
engine will stop. Try it with the return going into an open
container. Seems counter intuitive, but it will stop.
Regards
Neil |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
