Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1440 combine won't move
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters
old fashioned farmer
PostPosted: Sun Oct 28, 2012 3:32 am    Post subject: 1440 combine won't move Reply to specific post Reply with quote
Howdy folks,
Looking for some ideas on what to try with my 1440. Had to install a new hydro motor down at the transmission but the combine is still not moving. When you put it in gear and move the hydro lever forward or in reverse the combine kind of shudders and then there is nothing. Any ideas would be appreciated. Thanks.
--old fashioned farmer
Erik Ks farmer
PostPosted: Sun Oct 28, 2012 4:18 am    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
There is air in the system, if you have an operators manual there are direction in it on how to bleed the system.
PostPosted: Sun Oct 28, 2012 5:03 am    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
I wondered about that. I went through the steps the manual had when you drain the system. Maybe it didn't quite get the air out. Thanks for the input. God bless.
MN Scott
PostPosted: Sun Oct 28, 2012 5:34 am    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
You replaced the hydro motor and not the pump to? When one fails it fills the other with metal shavings and pretty much ruins it to. Good practice to go thru both the pump and motor for a long lasting repair.
ohiompuller
PostPosted: Sun Oct 28, 2012 6:05 am    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
Check the drive hub or the pump shaft. The cast hubs will take the splines out. Have someone start the combine and make sure the input shaft to the hydro pump is turning. I have replaced a lot of these pieces.
tjiniowa
PostPosted: Sun Oct 28, 2012 3:20 pm    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
Need to change both the pump and the motor together as one unit. One will ruin the other
Dalet
PostPosted: Sun Oct 28, 2012 8:23 pm    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
Replace the pump, motor, filter, fluid and bleed the air. If the drives are turning, replace the shafts too. If the shafts are stripped, you wasted lots of cash on the preceding advice. Embarassed
PostPosted: Tue Oct 30, 2012 5:29 am    Post subject: Re: 1440 combine won't move Reply to specific post Reply with quote
Howdy,
Just a quick update on the 1440. Dad and I were able to pull the combine into the shop (after disconnecting the shafts from the transmission to the drives). I may have blown the money on the new hydro. Apparently there is a bearing out in my transmission. Not too sure of the damage extent yet as I haven't dropped it out. Will be doing that this morning. Several ball bearings fell out when I drained the transmission yesterday evening.
I was sure that the hydro was the culprit before as there was a pretty bad sound coming from it before I replaced it but now I am wondering if my ears are just bad and the sound was actually coming from the tranny.
I appreciate the advice, especially on the replacing the pump and motor at the same time. New to these things so I did not know that. Hopefully can get this puppy back up and running so that when the snow from Sandy goes away we can finish our corn. God bless.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
