| Author |
Message |
DON TX Tractor Expert
Joined: 09 Aug 2001 Posts: 2248 Location: Midlothian, Tx
Posted: Sun Oct 28, 2012 10:01 am Post subject: How to flush the head? |
I have the head to a TE 20 that is plugged up. I really don't want to remove it. If it was a flat head, I'd do it. I'm not real confident with an overhead valve setup. Is there any way to flush it? I've had CLR setting in it for 24 hrs and no movement yet. TIA
DON TX |
| Back to top |
Bob Harvey Tractor Guru
Posted: Sun Oct 28, 2012 10:17 am Post subject: Re: How to flush the head? |
My immediate thought was, open the valve and pump the handle ! |
| Back to top |
Posted: Sun Oct 28, 2012 10:51 am Post subject: Re: How to flush the head? |
Not sure I follow. What valve and pump handle?
DON TX |
| Back to top |
Britcheflee Long Time User
Joined: 20 Aug 2007 Posts: 1398 Location: Placerville California
Posted: Sun Oct 28, 2012 10:57 am Post subject: Re: How to flush the head? |
| DON TX wrote: | (quoted from post at 11:51:21 10/28/12) Not sure I follow. What valve and pump handle?
DON TX |
Well, I think he was making a bit of a joke - different kind of head....do you think that the same stuff you use to do a radiator flush might work?
I somewhat doubt CLR would do much - probably need some industrial strength stuff to shift that - then there is the risk of loose gunk getting into the water pump and jamming that up. Good luck.
Lee |
| Back to top |
Posted: Sun Oct 28, 2012 11:08 am Post subject: Re: How to flush the head? |
I had a feeling it was a funny, but I guess it went over my head. (Pun intended). The thought occurred it could just move to another spot. Since the pump is off I hope it would flush out. The radiator flush from Prestone uses sodium citrate and says it isn't acidic. CLR says not to get it on your flesh so I figure it might be stronger. Could be wrong. I'm leaning toward muriatic acid but would water it down.
DON TX |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12411 Location: Twin Cities
Posted: Sun Oct 28, 2012 11:43 am Post subject: Re: How to flush the head? |
Don,
On a ship the toilet is called the head.
So when you ask about flushing the head you're gonna get some snickers. |
| Back to top |
Posted: Sun Oct 28, 2012 12:14 pm Post subject: Re: How to flush the head? |
I've been on a lot of boats but no ships. I have heard it called the "head" (my Dad was in the Navy). I chose the AF. (%^)
DON TX |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50398 Location: Lake of the Ozarks area of MO
Posted: Sun Oct 28, 2012 3:17 pm Post subject: Re: How to flush the head? |
Very simple and no head jokes even if I am former navy. Drain the cooling system. Fill the cooling system with vinegar run it till work let cool drain and then back flush by way of the block drain. Rig up a way to hook a garden hose to the block drain and let it flow for an hour or so. If real bad strain the vinegar and then fill the system back up and run again. Vinegar will clean out rust and lime etc and works very well |
| Back to top |
JMOR Tractor Guru
Posted: Sun Oct 28, 2012 4:21 pm Post subject: Re: How to flush the head? |
| old wrote: | | (quoted from post at 19:17:19 10/28/12) Very simple and no head jokes even if I am former navy. Drain the cooling system. Fill the cooling system with vinegar run it till work let cool drain and then back flush by way of the block drain. Rig up a way to hook a garden hose to the block drain and let it flow for an hour or so. If real bad strain the vinegar and then fill the system back up and run again. Vinegar will clean out rust and lime etc and works very well | I did just that & repeated twice, allowing it to do its work for a week each time & it did get a lot of rust out. |
| Back to top |
Posted: Sun Oct 28, 2012 5:12 pm Post subject: Re: How to flush the head? |
Ok. Wasn't sure if the vinegar would be strong enuff. I'll find some 10% and fill the head till I get some circulation. then button it up and refill completely, run til it's hot, repeat. Does vinegar work better when it's hot?
DON TX |
| Back to top |
JMOR Tractor Guru
Posted: Sun Oct 28, 2012 5:59 pm Post subject: Re: How to flush the head? |
| DON TX wrote: | (quoted from post at 21:12:49 10/28/12) Ok. Wasn't sure if the vinegar would be strong enuff. I'll find some 10% and fill the head till I get some circulation. then button it up and refill completely, run til it's hot, repeat. Does vinegar work better when it's hot?
DON TX | Don't know if it works better hot. I ran it because I thought circulation 'might' help. |
| Back to top |
old Tractor Guru
Posted: Mon Oct 29, 2012 6:58 am Post subject: Re: How to flush the head? |
Yes any acid which is what vinegar is works better when hot. Water which is a universal solvent works better hot and that is why you wash dishes in hot water LOL or at least one of the reason |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
