| Author |
Message |
oldtanker Tractor Guru
Posted: Sun Oct 28, 2012 2:47 pm Post subject: 6 volt genny |
I have a 6 volt genny laying around in my way from when I converted my N to 12 volt. Worth holding onto? I'll never use it.
Rick |
| Back to top |
JMOR Tractor Guru
Posted: Sun Oct 28, 2012 2:49 pm Post subject: Re: 6 volt genny |
| oldtanker wrote: | (quoted from post at 18:47:14 10/28/12) I have a 6 volt genny laying around in my way from when I converted my N to 12 volt. Worth holding onto? I'll never use it.
Rick | Someone who wants to keep his tractor original will need it worse than the scrap guy who will melt it and send it to China. |
| Back to top |
Royse Tractor Expert
Posted: Sun Oct 28, 2012 2:54 pm Post subject: Re: 6 volt genny |
I agree with JMOR, if its serviceable, offer it to someone restoring an N for a reasonable cost.
That gets it out of your way and gives someone a part they may need. |
| Back to top |
Posted: Sun Oct 28, 2012 3:18 pm Post subject: Re: 6 volt genny |
Hey if someone needs it they can have it. It was working when I removed it from the tractor.
Rather give it to someone than to scrap it.
Rick |
| Back to top |
Dell (WA) Tractor Guru
Posted: Sun Oct 28, 2012 3:35 pm Post subject: Re: 6 volt genny |
Rick.........you do know 8N's had 2-types of 6-volt gennys, don't you? The 4-nipple fronmount genny on the RIGHT side of the engine ...and... the 5-nipple sidemount on the LEFT side of the engine. ........respectfully, Dell |
| Back to top |
Posted: Sun Oct 28, 2012 3:39 pm Post subject: Re: 6 volt genny |
| oldtanker wrote: | (quoted from post at 19:18:07 10/28/12) Hey if someone needs it they can have it. It was working when I removed it from the tractor.
Rick |
If no one else jumps on it, I would be happy to pay the shipping for it Rick.
I don't have a particular need for it at the moment, but I have several N's that are still 6 Volt.
Email is open on modern view. |
| Back to top |
Mr. T. Minnesota Regular
Posted: Sun Oct 28, 2012 3:55 pm Post subject: Re: 6 volt genny |
OT,
Open the bids!! I run a 2N in northern Minnesota that has a 6volt generator on it. Don't know the difference between 4 or 5 but have a three brush on the 2N and also have a voltage regulator for the newer version. Would be nice to have the voltage regulated. Let me know what you decide.
Thanks,
Mr. T. Minnesota |
| Back to top |
Posted: Sun Oct 28, 2012 5:31 pm Post subject: Re: 6 volt genny |
OK Dell I didn't know that there is a difference in the gennies. This is off of a 8N front mount.
So who ever needs or wants it.
Rick |
| Back to top |
Posted: Sun Oct 28, 2012 5:33 pm Post subject: Re: 6 volt genny |
| Mr. T. Minnesota wrote: | (quoted from post at 16:55:00 10/28/12) OT,
Thanks,
Mr. T. Minnesota |
Where at in MN? I'm near Fergus Falls.
Rick |
| Back to top |
Posted: Sun Oct 28, 2012 6:58 pm Post subject: Re: 6 volt genny |
OT,
Thanks for the reply! Does the generator have one or two terminals on the case? If it has one terminal it is a three brush. If it has two terminals on the case it is a two brush which uses a voltage regulator. Either way I am interested in the generator. I am in just north of Brainerd about 8 miles. Thanks again!
Mr. T. Minnesota |
| Back to top |
Posted: Sun Oct 28, 2012 9:03 pm Post subject: Re: 6 volt genny |
I never really looked at it.
It has 3 terminals. 2 on the main body and one on the end cap. I also noticed that it has what looks to be an adjustment on the end cap too.
I'm just about 80 miles west of Brainard, right on highway 210.
Rick
| Back to top |
JMOR Tractor Guru
Posted: Sun Oct 28, 2012 9:45 pm Post subject: Re: 6 volt genny |
| Mr. T. Minnesota wrote: | (quoted from post at 22:58:47 10/28/12) OT,
Mr. T. Minnesota | Nope, it is the first generation 8N generator, with 3 terminals AND 3 brushes. It did use a VR, but has only 11 amp output. 8N10000A. |
| Back to top |
Posted: Mon Oct 29, 2012 1:49 am Post subject: Re: 6 volt genny |
JMOR,
I learned something on the Forum again. Thought there were only two versions- one post on the case and two on case with a rear post (3 total). Did they eliminate the high/low set screw later on?
Mr. T. Minnesota |
| Back to top |
JMOR Tractor Guru
Posted: Mon Oct 29, 2012 3:46 am Post subject: Re: 6 volt genny |
| Mr. T. Minnesota wrote: | (quoted from post at 05:49:35 10/29/12) JMOR,
Mr. T. Minnesota | 8N initial production through SN 137,684 used generator 8N10000A (3 brush) with regulator 8N10505A. When Service Bulletin #78 3rd brush removal was performed, the regulator was changed to 8N10505B.
At SN 137,685 the generator is 8N10000B (2 brush) with regulator 8N10505B.
At SN 263844, the distributor is moved to the side & generator 8N10001 moved to left side, with 8N10505B regulator.
At SN 308,455 the regulator changed to 8N 10505C (generator remains 8N10001). 8N10505B and 8N10505C regulators are electrically the same, but mounting is different.
8N10505B replacement applications are supplied with a mounting bracket such that the 8N10505C regulator will fit the older tractors.
8N10000A generators were 11.5 ampere output units using 8N10505A regulator.
8N10000A with 3rd brush removal AND 8N10505B regulator had, "materially increased amperage output".
8N10000B generators had 20 ampere output.
8N10001 generators were 20 ampere output units with either the B or C regulator.
Rick: would you do me a favor and measure the length of the cylindrical barrel portion of your 8N10000A generator (do not include the end plates in measurement). Also, wrap the tape measure around the barrel so as to measure the circumference. I thank you in advance for taking these measurements for me. |
| Back to top |
Posted: Mon Oct 29, 2012 4:29 am Post subject: Re: 6 volt genny |
6 1/8 inchels long.
14 1/2 around.
Rick |
| Back to top |
