| Author |
Message |
RUSS JONES New User
Posted: Sun Oct 28, 2012 5:43 pm Post subject: 6610 power steering leak |
i have a 1992 6610 series 2.there is a weep hole on the bottom side of the housing,under the tractor that is leaking power steering fluid but i cant seem to find where it is coming from.could someone steer me in the right direction? |
| Back to top |
Bern Tractor Expert
Posted: Sun Oct 28, 2012 5:58 pm Post subject: Re: 6610 power steering leak |
If you have PS fluid coming out the bottom of the trans (if I understand you correctly), then it can only be coming from a leak on the bottom of your steering motor, the part of it you can't see. |
| Back to top |
showcrop Tractor Guru
Posted: Mon Oct 29, 2012 2:48 am Post subject: Re: 6610 power steering leak |
Can you supply more/better info? What weep hole? which housing? how do you know that it is PS fluid? |
| Back to top |
RodinNS Tractor Guru
Posted: Mon Oct 29, 2012 2:43 pm Post subject: Re: 6610 power steering leak |
If it's. Actually ps fluid then it's coming from under the steering motor that's bolted to the top of the transmission housing. However... If it's not ps fluid.... And it could be transmission fluid... Then you've got a leeaking tranny front seal...
Rod |
| Back to top |
RUSS JONES New User
Posted: Mon Oct 29, 2012 3:21 pm Post subject: Re: 6610 power steering leak |
Thanks. I only use the tractor to plant food plots for hunting season. Maybe get a chance to work on it this weekend after I get out if the woods. |
| Back to top |
Ron Stazick Regular
Posted: Sat Dec 01, 2012 3:28 am Post subject: Re: 6610 power steering leak |
I had the same problem on my 1983 6610. I bought the seal kit for the steering column and replaced the seals in the column. I did not do the seals on the lower section, did not want to get that far into it. Took me an afternoon, did not have to remove the fuel tank. That was 3 years ago and problem solved.
I originally thought it would be a lot tougher than it was. Toughest thing was getting the steering wheel off with out the proper puller.
Hope that helps. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
