Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
hard steering 1370
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
gary r schenck
PostPosted: Sun Oct 28, 2012 5:44 pm    Post subject: hard steering 1370 Reply to specific post Reply with quote
having trouble with 1370 case steering ,steering wheel tuff to turn even when moveing,took steering motor apart,was not in very good shape,put in a rebuilt one, wasnt much better.lifted front end off of the ground,thinking might be frozen bushings in front axle, no not that ethier.drained hydrolic oil put in new filters,took out charge pump checked forwear, looked good,took out rightside hyd pump, no seals blown out,no exesive wear in either 8gal or 20gal side of pump,took relief valve apart for steering motor,cleaned up put back together.when you turn the wheel full left to right an hold it, you can hear the relief valve open.for some reason it does seem to turn a little easyer when the motor is at lower rpms any ideas
Agri King
PostPosted: Mon Oct 29, 2012 3:46 am    Post subject: Re: hard steering 1370 Reply to specific post Reply with quote
T a 3000 psi guage in at the steering cyls. What is the psi?
oldabe30
PostPosted: Mon Oct 29, 2012 4:37 am    Post subject: Re: hard steering 1370 Reply to specific post Reply with quote
On mine the A59979 pressure relief washer was broke, in the brake valve.
turbo
PostPosted: Mon Oct 29, 2012 9:47 am    Post subject: Re: hard steering 1370 Reply to specific post Reply with quote
Try lubing bearings in steering column in cab.
Case Nutty 1660
PostPosted: Mon Oct 29, 2012 11:22 am    Post subject: Re: hard steering 1370 Reply to specific post Reply with quote
if you find nothing from the guy's advise, thhe better steering at lower rpm could be the flow divider in the brake valve is dumping too much to the brakes or lube, one other thing I have seen on them is a piston gland may be floating in one cylinder(nut comes loose or threads strip) couple more things to think about cnt
