Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Super Rust Breaker, (slightly long)
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
ShadetreeRet
PostPosted: Sun Oct 28, 2012 9:19 pm    Post subject: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
I guess penetrating oil qualifies as a tool.
So last spring my daughter calls and wants me to come down and re-set the angle on her disc. (It's one of those "economy" units where you have to loosen the brackets and slide the disc gang to whichever hole you desire to get the desired angle.) On the way I stopped at the local hardware for some penetrating oil, just in case. He only had a couple of cans, one I didn't like and one that I had never seen before, but I bought it. I think it was about seven dollars, but that was cheaper than driving 30 miles round trip to town and back. Didn't need it, brought it home and put it on the shelf.
OK, a few weeks ago I had to loosen the feeder pipe on the EGR valve on one of my trucks. And if you have ever tried to loosen one of those suckers, you know what I'm talking about! Liquid Wrench didn't do any good, then I spotted this stuff. Gave it a good shot and when I put a wrench on it, it felt cold! What the heck? Maybe it's time to read the instructions. Read the label and it contains 1,1-Difluoroethane! "Freezes & breaks rust loose when nothing else will!" So I gave it a good shot for 5 or 10 seconds like it said, and I'll be danged if it didn't work! Don't know if anyone else has tried it or not, it's called Next Dimension. Super Rust Breaker. Kinda pricey, but it does seem to work. Just thought I would pass this along.
Duner Wi
PostPosted: Mon Oct 29, 2012 4:04 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Been meaning to get some of that stuff.
Inno
PostPosted: Mon Oct 29, 2012 6:15 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Sounds like freeze spray which is used in electronic service for pinpointing faulty components. At a pinch you can also get a can of "compressed air" or duster and turn the can upside down, you will get the same effect. Never thought of trying it on rusty/siezed nuts etc. will have to try.
Jim in N.M.
PostPosted: Mon Oct 29, 2012 8:08 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Where can I get this stuff ?? Jim in N M
ShadetreeRet
PostPosted: Mon Oct 29, 2012 9:38 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Jim, I don't know where you might find it in NM. A hardware or parts house I would think.
It is mfgd. by AMREP. INC. Automotive Products Group, 990 Industrial Park Drive, Marietta, GA. 30062. 800-241-7766. Might give them a call and find out if it is available in your area.
ShadetreeRet
PostPosted: Mon Oct 29, 2012 9:44 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Yes, It is the heat/cold, or expansion/contraction principle. To install bushings, bearings, etc. you either heat or chill them, this just makes it easier to loosen things if they are too large to put in the refrigerator. LOL. And of course, in the instance of a EGR pipe, heat would not work well because that is why it is so darned hard to get loose in the first place. This stuff causes the metal to contract so fast that it breaks rust, etc. loose.
Inno
PostPosted: Mon Oct 29, 2012 11:51 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Or go to an office supply store or Wal-Mart and buy some duster. Tip the can upside down and spray, same effect.
It also works for getting gum off of carpet. Freeze it and then it will chip right off.
JRSutton
PostPosted: Mon Oct 29, 2012 2:16 pm    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
as others have said, duster turned upside down works too - but then again - if you're going to buy duster, you might as well use this stuff and use it rightside up.
But there are much cooler things you can do with it than freeze rusty parts.
For example, you can freeze flies with it.
It'll freeze them solid.
A few minutes later, they'll thaw out and start moving - they'll be flying again within 5 minutes.
504
PostPosted: Mon Oct 29, 2012 5:23 pm    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Liquid Nitrogen(but I haul it for a living)
Bendee
PostPosted: Mon Oct 29, 2012 7:31 pm    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
Ice cube on the gum does the same thing.
RodinNS
PostPosted: Tue Oct 30, 2012 5:15 am    Post subject: Re: Super Rust Breaker, (slightly long) Reply to specific post Reply with quote
I use combustion chamber cleaner. Iirc, it's got about the same active ingredients...
Rod
