| Author |
Message |
Travwm New User
Posted: Mon Oct 29, 2012 3:37 pm Post subject: IPTO Clutch for 1967 Case 430 Farm Tractor |
Hi Everybody, I am trying to adjust the IPTO Clutch on a Case Model 430. I can't get it to release. The spring loaded pin does not seem to push in correctly in order to release the clutch adjustment plate to turn for the adjustment.
Any ideas, or diagrams from a factory manual that could help me? Clymers Manual doesn't address it very well.
Thanks much!
Trav |
| Back to top |
Case Nutty 1660 Tractor Guru
Posted: Mon Oct 29, 2012 4:37 pm Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
did you try both pins? one is always locked one is not gives a finer adjust that way cnt |
| Back to top |
casecollectorsc Long Time User
Posted: Mon Oct 29, 2012 5:12 pm Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
You pull the pin out and turn the collar and the other pin will drop in to lock it . Repeat until you have it correct. |
| Back to top |
mEl Tractor Guru
Posted: Tue Oct 30, 2012 2:40 am Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
| Travwm wrote: | (quoted from post at 16:37:30 10/29/12) Hi Everybody, I am trying to adjust the IPTO Clutch on a Case Model 430. I can't get it to release. The spring loaded pin does not seem to push in correctly in order to release the clutch adjustment plate to turn for the adjustment.
Thanks much!
Trav |
You have the late PTO with the flat pin and scalloped washer if I am correct, I would not know why the button will not push in to release the washer. Is there pressure on it by any chance? Did you try putting something against it and gently tapping it. That PTO unit was the last of those series and if I am correct it has NO pins to pull, just push the button and turn the pto till it snaps back out in the scalloped washer. I wonder if someone has the capability of posting a pic of that unit?.
mEl |
| Back to top |
Posted: Tue Oct 30, 2012 3:51 am Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
mEl here is the adjustment procedure if you think a parts breakdown would be helpful I can do that also, my other info was incorrect as I was thinking these had two lock pins like the big brother tractors I do know the last time I adjusted one it took a bit to get the adjustment to turn hope this helps a little cnt |
| Back to top |
Travwm New User
Posted: Tue Oct 30, 2012 4:55 am Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
You are correct. This one has no pins to pull. It has one round pin that is spring loaded, pushes in to release from the scalloped washer.
It should push in with little effort but does not.
A good parts diagram would be helpful.
Thanks,
Trav |
| Back to top |
Posted: Tue Oct 30, 2012 5:30 am Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
this is a breakdown from the service manual cnt
| Back to top |
Joe Young Long Time User
Joined: 05 Mar 2009 Posts: 921 Location: Olathe KS (Kansas City Area)
Posted: Tue Oct 30, 2012 8:13 am Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
Same diagram from the parts manual....
| Back to top |
Travwm New User
Posted: Tue Oct 30, 2012 12:27 pm Post subject: Re: IPTO Clutch for 1967 Case 430 Farm Tractor |
Thanks Joe,
Would you have the parts list to go along with this?
Thanks,
Trav |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
