| Author |
Message |
Troy Benner New User
Posted: Mon Oct 29, 2012 4:02 pm Post subject: oliver super 77 noise, need help! |
Hi everyone, new to the forum and tractor in general. I have a question about a super 77 with the gas 6 cyl in it that I just bought. It seems to have a noise in the motor when its running free as in no load. I cant really seem to hear it when moving or when I am using hydraulics. But then it returns once you stop or quit using the hydraulics. You can even seem to feel it some throughout the tractor and when you touch the crankcase. I dont seem to feel it when i touch like the generator or valve cover nearly as much so it makes me think its internal. Although it doesnt really sound like a rod noise to me, maybe a thrust issue since it stops when loaded? Any thoughts on this would really be appreciated! |
| Back to top |
Dick W. Long Time User
Posted: Mon Oct 29, 2012 4:27 pm Post subject: Re: oliver super 77 noise, need help! |
Timing gears? |
| Back to top |
Posted: Mon Oct 29, 2012 4:32 pm Post subject: Re: oliver super 77 noise, need help! |
its very possible, I dont know anything about these motors and sometimes the noises can be hard to track down. Are the gears in this motor close to the mid point by the distributor? |
| Back to top |
J. Schwiebert Guest
Posted: Mon Oct 29, 2012 5:25 pm Post subject: Re: oliver super 77 noise, need help! |
No, but noises travel and can be misleading as to where they originate. Can you short out one cylinder at a time and see if the noise goes away.? |
| Back to top |
Posted: Mon Oct 29, 2012 5:31 pm Post subject: Re: oliver super 77 noise, need help! |
yes thats a good idea to see if its related to a particular cylinder |
| Back to top |
chucksoliver77 Long Time User
Posted: Mon Oct 29, 2012 6:53 pm Post subject: Re: oliver super 77 noise, need help! |
could be wrist pin bushings. chuck |
| Back to top |
G3400 Guest
Posted: Tue Oct 30, 2012 12:02 am Post subject: Re: oliver super 77 noise, need help! |
I wouldn't rule out a throw out bearing on the clutch. |
| Back to top |
C.R. Long Time User
Joined: 05 Oct 2009 Posts: 1055 Location: south centeral wisconsin
Posted: Tue Oct 30, 2012 1:34 am Post subject: Re: oliver super 77 noise, need help! |
get a really long dowel or something similar and use it as a stethascope and listen to one end and touch the other end to different places on your tractor |
| Back to top |
Row Crop Regular
Posted: Tue Oct 30, 2012 2:04 am Post subject: Re: oliver super 77 noise, need help! |
Like I tell my wife when she hears a funny noise in the car.."Turn up the radio!" |
| Back to top |
Jordan Bergsma Regular
Posted: Tue Oct 30, 2012 2:09 am Post subject: Re: oliver super 77 noise, need help! |
Could be the pilot bushing if you find its not in the engine. The shaft that runs the hyds. rides on the pilot bushing. |
| Back to top |
ollie4 Guest
Posted: Tue Oct 30, 2012 3:25 am Post subject: Re: oliver super 77 noise, need help! |
I would pull off the PTO cover and then pull out the PTO shaft that goes up in the engine,, this might help isolate the problem area. |
| Back to top |
rrlund Tractor Guru
Posted: Tue Oct 30, 2012 5:51 am Post subject: Re: oliver super 77 noise, need help! |
That wouldn't be unusual for one of'em. |
| Back to top |
Mike in MI Long Time User
Posted: Wed Oct 31, 2012 5:20 pm Post subject: Re: oliver super 77 noise, need help! |
Troy,
I agree with ollie4. I"d pull the PTO Shaft and go from there. Doesn"t take that long to pull it. Four bolts underneath the power take off shaft. Then remove cover. Then remove 3 bolts in behind of the pto clutch pack then if the noise still persist I"d say it be in the engine itself.
Mike |
| Back to top |
Posted: Wed Oct 31, 2012 6:55 pm Post subject: Re: oliver super 77 noise, need help! |
thanks for all the suggestions everyone, I have tried some with no change, havent done the PTO but will try this weekend, also found a very knowledgeable local guy who said he would stop by and take a listen |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
