Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
JB Weld
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
CH(upstate,NY)
PostPosted: Mon Oct 29, 2012 4:32 pm    Post subject: JB Weld Reply to specific post Reply with quote
Is it gasoline proof? Tanked my genny carb Friday, blew it out and reassembled it. Genny ran a little rough until I shut the fuel off than ran smooth until it ran out. Took the carb apart and found one of the ears that the pin that holds the float broke. Put a little JB to hold the pin and let it sit in case I needed it tonight.
So it it gas proof? If not, any recommendations?
JB weld
PostPosted: Mon Oct 29, 2012 4:57 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
I think it could work but leave it for 24 hours to dry.
504
PostPosted: Mon Oct 29, 2012 5:11 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
You really never know, if you got it clean and let it sit for 24 it may work fine. There is a product made to use in gas too.
Dean
PostPosted: Mon Oct 29, 2012 5:19 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
Gasoline tolerant epoxies are available. I've used such to repair worn float pin bores in Ford/Holley carburetors.
Dean
JMS./MN
PostPosted: Mon Oct 29, 2012 5:25 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
I used JB weld and fiberglas stripping to patch a Ford p/u tank over 5 years ago- corroded around the mounting straps. Warmed the JB tubes in hot water- mixed easier. Was a second tank, so let it dry a couple weeks. Still holds now.
redtom
PostPosted: Mon Oct 29, 2012 5:56 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
won't last. Bought a tractor once, ran good for a while then flooded. Took carb apart, seller had glued the brass float to the arm with JB, gas "melted" the JB.
Ultradog MN
PostPosted: Mon Oct 29, 2012 6:08 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
If I was the dictator of all the world the first thing I would do is outlaw JB Weld.
Then I would outlaw women voting.
I used JB on a carb bowl once and it did not last more than a week or so and it sluffed off.
I have also cleaned and soldered more than one fuel tank that someone used JB on.
I find little use for the stuff.
t.r.k.
PostPosted: Mon Oct 29, 2012 6:16 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
3 years ago the tank in my '69 1 ton started leaking. Pretty big deal since its in the back of the cab. So I replaced the tank.
On the bottom of the old tank was an old JB-weld patch. I bought the truck in '93 so it was on there then. . . 18 or 19 years. But I wonder if it was really the ethanol in the gas that loosened it up.
Your post reminds me of the Auto Mechanics shop back in the 80's. I broke a float lug off on a carb. in a volkswagen rabbit. My teacher told me to take it and show it to the instructor in the welding shop.
The old guy-probably 60+ years old- builds up the area with something he called 'sil-fos' or some such, cuts it back to shape with a Dremel Tool and drills a new hole for the float pin.
It worked fine.
G1355
PostPosted: Mon Oct 29, 2012 6:24 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
I had luck but I let my tank sit empty for a week a year later it still holds
M-MAN
PostPosted: Mon Oct 29, 2012 8:56 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
The old slow drying jb weld is gas proof when cured properly. Had an old mac chainsaw with a fuel tank busted half into that I put back together with it. Ran that saw several more years & it never let go. Try to use it like glue & it won't work.
Jason S.
PostPosted: Tue Oct 30, 2012 5:13 am    Post subject: Re: JB Weld Reply to specific post Reply with quote
In general regular JB Weld will hold for a while but it usually turns loose, but go get a pack of JB Marine Epoxy it is much more resistant to fuel.
JRSutton
PostPosted: Tue Oct 30, 2012 8:23 am    Post subject: Re: JB Weld Reply to specific post Reply with quote
I had a carb float crack off once - tried jbwelding it back in place as it was my only real choice before rain got on the hay that was down.
Lasted a few months, but eventually got all rubbery and fell apart.
Somebody said it has to cure properly to work - and they may be right. I certainly didn't let my bandaid job cure properly - had to get it back up and running quickly.
Jim in LA
PostPosted: Tue Oct 30, 2012 1:44 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
My Dad patched the gas tank on our 8n with JB weld. He used a piece of pillow case saturated with JB weld that had been thinned with paint thinner and it is still holding. I think we used about four tubes. The patch was about 6x8 inches. We first tried using gas tank epoxy but the patch just fell off after curing. A neighbor told him to use the JB weld and paint thinner and it worked. I used JB weld to seal a cracked brass emulsion tube (i think that's the right term) on my Harley carburetor years ago and it held up until last year when I disassembled the carburetor, I discovered the JB weld had started to soften. One of these days I will get around to patching it again so I can go riding.
Mark6005
PostPosted: Tue Oct 30, 2012 2:43 pm    Post subject: Re: JB Weld Reply to specific post Reply with quote
Only used it once 18-20 years ago on a couple leaks on my 8n radiator. Still have the 8n and no leaks. Hope I didn"t jinx it
dave2
Location: Kutzberg, Germany 1972 IHC 423 (German). 2.5 Liter 3cyl direct injection diesel 42HP
PostPosted: Wed Oct 31, 2012 1:27 am    Post subject: Re: JB Weld Reply to specific post Reply with quote
I think so....... Prolly the main problem with the stuff (that gives it the bad name) is the users that needed a "quick fix" and done the preperation "quick" also.....
Goto page 1, 2  Next
Page 1 of 2
