Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
ford 4500 tlb no start
Post new topic    Yesterday's Tractors Forum Index -> Ford
Notsofastfreddie
PostPosted: Mon Oct 29, 2012 5:23 pm    Post subject: ford 4500 tlb no start Reply to specific post Reply with quote
I have a 1969 Ford TLB that will not start, even with ether. Replaced fuel filter, primed but no fire. Jumped battery with diesel truck, and used ether but still no fire. Checked shutoff cable on pump, is against stop. Tractor has been sitting about a year. Did not run well then. I'm stumped. Any suggestions would be appreciated. Thanks, Fred
JF in CT
PostPosted: Tue Oct 30, 2012 4:48 am    Post subject: Re: ford 4500 tlb no start Reply to specific post Reply with quote
I would unscrew the fuel fittings at the injectors, open the throttle wide and crank it to see if you are getting fuel. Is it cranking fast enough? Is the thermostart injector working? Mine won't start without it in cooler weather.
Jim
Notsofastfreddie
PostPosted: Tue Oct 30, 2012 5:38 am    Post subject: Re: ford 4500 tlb no start Reply to specific post Reply with quote
Thanks Jim. Not to rub it in, but it was 70 degrees here in CO yesterday. There is very little fuel squirting out at the injector lines. With the truck tied to the battery, it seems to be spinning ok. What I don't get is that spraying ether directly into the manifold does not get any reaction, violent or otherwise. Hate to spend $$ on a new pump when the engine is shot. Last time it ran had lots of blowby and low power. Fred
RodinNS
PostPosted: Tue Oct 30, 2012 7:26 am    Post subject: Re: ford 4500 tlb no start Reply to specific post Reply with quote
How much blow did you give it? I'd try some more...mabey a 2-3 second shot while cranking aand see if it stumbles some. If it doesn't, try some more. If it won't try on a steady shot while cranking for 5-10 seconds then I'd say you have no compression
Rod
Ultradog MN
PostPosted: Tue Oct 30, 2012 7:28 am    Post subject: Re: ford 4500 tlb no start Reply to specific post Reply with quote
I am not so good with injector pumps so others here will correct me if I get some of the terminology wrong.
If you open the top cover on the pump you will see the shut off shaft #4 moves the shut off bar #3.
The shut off bar in turn moves the metering valve #10.
Twice now on two different pumps the metering valve was stuck. I had to open the top cover and free it up. It is all very delicate in there so you want to tread lightly.
Once the pump had only been sitting for a year and another time it had sat for many years.
Both times I was able to open the cover and free up the metering valve and the tractor started right up after that.
Notsofastfreddie
PostPosted: Wed Oct 31, 2012 12:46 pm    Post subject: Re: ford 4500 tlb no start Reply to specific post Reply with quote
Thanks, Ultradog. Will try taking the cover off next week. Is there anything I have to worry about flying off when the cover comes off? That seems to make the most sense, considering no reaction to numerous ether shots. Fred
RodinNS
PostPosted: Thu Nov 01, 2012 7:58 am    Post subject: Re: ford 4500 tlb no start Reply to specific post Reply with quote
If you can't make that engine RUN on ether you have far more serious problems than the pump. Freeing the metering valve is not a big deal if it will fire on ether...
Rod
