| Author |
Message |
Richard from SE AZ Long Time User
Posted: Mon Oct 29, 2012 9:00 pm Post subject: Will charge no more. |
I have tried to keep everything working on my 2N the way it should. But,I have never been able to get the cutout to release so I have made it a habit to disconnect the battery after using the machine.Well, I got distracted by a strong wind that came up and in my hurry to shut the shop doors I forgot to take off the battery cable. Now it won't charge. Any ideas as to what I burned up? |
| Back to top |
JMOR Tractor Guru
Posted: Mon Oct 29, 2012 9:11 pm Post subject: Re: Will charge no more. |
| Richard from SE AZ wrote: | | (quoted from post at 01:00:01 10/30/12) I have tried to keep everything working on my 2N the way it should. But,I have never been able to get the cutout to release so I have made it a habit to disconnect the battery after using the machine.Well, I got distracted by a strong wind that came up and in my hurry to shut the shop doors I forgot to take off the battery cable. Now it won't charge. Any ideas as to what I burned up? | Not a lot of possibilities there..........cut out or generator.
Jumper across cut out & see if it charges.........if not generator is likely...unless some wiring/connections burned up. |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Oct 30, 2012 5:06 am Post subject: Re: Will charge no more. |
i agree with jmor.. check the cutout.. it may have finally opened for you :)
If it is the cutout.. gut it and hit radio shack and buy a 25a full wave bridge and wire in one of the segemnts across the arm / bat terminals on the cutout.
for positive ground.. that means gen provides (-).. thus the diode symbols need to be wired a specific way.
one side has a flat line, the other a triangle.
wire the flat line side to arm, and the triangle side to bat.
it's good for 25a which is mor ethan 2x what your genny can make.. and it's got 3 built in spares IF that segment ever gives out.
or you could parallel a set of segments and have 50a capacity.. , and a spare.. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
