Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Timing sight hole
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Harry Ferguson
HillsofTn
PostPosted: Tue Oct 30, 2012 3:27 am    Post subject: Timing sight hole Reply to specific post Reply with quote
I am rebuilding a To20 that has a badly cracked block. I have a replacement block from an early TE20 and it doesn"t have the timing hole. Is there any downside to just drilling one and then adding my own timing marks to match the ones on my other To20? (Which will also provide me with the proper location of the timing hole.)
maxwell99
PostPosted: Tue Oct 30, 2012 3:52 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
i see no problem in drilling the new hole.
question: how did they time the engine on the motor with the new to you block.
they must have had a way to do it, if you figure that out, just time the motor the way they did it and you would not have to drill the new hole.
bet someone on the forum knows how they did it.
Richard L
PostPosted: Tue Oct 30, 2012 4:09 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
hopefully this will link you to what I found in the ARCHIVES as that is a good place to look for most questions. Look at the the posts by John it explains where the timing marks are. http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ferg&th=1068
trac
PostPosted: Tue Oct 30, 2012 4:57 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
Yeah John UK told me how to time my TEA i did not have the timing marks i'm sure its still in my email i'll try and send it to you if you would like. As far as drilling a hole it won't work theres a slide type mark in the hole that lines up with the marks flywheel. Wait just thought about it take starter off look in that hole for the grooved timing mark that must be it.
John(UK)
PostPosted: Tue Oct 30, 2012 5:34 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
It wont work as the timing is different on these two engines...John(UK)
John(UK)
PostPosted: Tue Oct 30, 2012 5:41 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
The Timing Marks on a TE20 Engine are on the Timing Cover and the marks are cast into the cover.
Tony in Mass.
PostPosted: Tue Oct 30, 2012 6:06 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
Ummmm...aghhhhh.... You have the inards of a Cont z120, but the block from a Standard? I am just thinking about the location of the dist etc. You better lay everything out to compare dimensions etc.... better talk to John UK and 2 (actually 7) tractors about this...
Jeff-oh
PostPosted: Tue Oct 30, 2012 7:06 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
He says he has the block of a TE20... That would be a Cont. Z120 also.
The Standard motor would be a TEA-20.
Jeff-oh
PostPosted: Tue Oct 30, 2012 7:11 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
John,
Just to make sure my understanding is clear.
The timing of the TEA-20 Std. motor and the TO-20 Cont. Motor would be different for sure.
Are you also saying the Timing of the TE-20 Cont. Z120 motor and the TO-20 Cont. Z120 is also different? Not sure what would cause that other than the Lucus Distributor.
You are constantly point out new information for me... Thank you.
PackardV8
PostPosted: Tue Oct 30, 2012 7:32 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
I am currently in the same situation as HillsofTN. I have a TE20 with Z120 Cont engine. IT has NO timing hole in the block apron under the starter. BUT it DOES have flywheel timing marks identcal to my other tractor a TO20 with Z120 engine.
I need to research a little further on this but my plan is to NOT drill the block. Plan is to count starter ring gear teeth on the TO20 and then re-mark the TE20 flywheel. That way i can time with a timing lite by removing the lower sheet metal flywheel cover.
However all of this raises a question:
Can a TO20 Z120 flywheel withfactory timing marks on flywheel be placed on a TE20 Z120 engine. THen drill the TE20 block for a timing hole and have all of it line up just fine for timing????? As i understand the John(UK) explanation above the answer to that question is No???
Tony in Mass.
PostPosted: Tue Oct 30, 2012 7:34 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
ohhhhh. This is like the baby seat commercial! I don't think I knew that... nope, I know I didn't know that...
So the one I helped the archery club with last year was a TEA? Should have brought my camera...
PackardV8
PostPosted: Tue Oct 30, 2012 7:40 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
See this thread:
http://ytforums.ytmag.com/viewtopic.php?t=955998&sid=17554f3c2da5aca6f06ecb92d4f04c03
especialy post:
Fri Oct 26, 2012 4:55 am About 2/3 the way down the thread.
Apparently the TE20's used miscellaneous methods of timing.
PackardV8
PostPosted: Tue Oct 30, 2012 9:31 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
From a post from above Richard L recommended viewing:
***EDIT: fixed following statement to reflect correct screen name as just "John". ****
Here is a very useful quote made by John from that thread for all TE owners:
* Ignition Timing Marks:* Quoting from a book by Tracprez: -
Continental engines (TE20) before tractor serial 36152 have a line on the
crankshaft pulley, which lines up with a mark on the timing gear cover, at
TDC.
If there is no mark on crankshaft pulley, remove the starter motor and find
two punch marks on flywheel housing in starter orifice, these will mate
with 2 marks on flywheel at TDC. After s/n 36151 there is a flywheel inspection
cover on the ignition side of the engine, when cover is removed a TDC mark
and single degree line can be lined up against a pointer exposed in the
inspection hole; note inlet valve opens, ie tappet clearance is taken up, at
TDC.
trac
PostPosted: Tue Oct 30, 2012 9:43 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
Always learning something new.
Richard L
PostPosted: Tue Oct 30, 2012 10:13 am    Post subject: Re: Timing sight hole Reply to specific post Reply with quote
I am not saying that is the same John it does not say John (UK) it just says John.
Goto page 1, 2  Next
Page 1 of 2
