| Author |
Message |
herk Regular
Posted: Tue Oct 30, 2012 8:44 am Post subject: 445 steam from radiator |
Hello I am looking at a 445 gas that after running a few min. steams from the radiator but it has no bubbles,(new cap ) no water in the oil ,temp gauge dosen"t go up (could be bad) also the motor seams to run hot ( muffler will glow red like you are pulling it hard ). The steam I think is a cracked head but the muffler getting hot puzzels me, timeing seems to be good ,any ideas Thanks Bryan |
| Back to top |
Alan K Tractor Expert
Posted: Tue Oct 30, 2012 9:40 am Post subject: Re: 445 steam from radiator |
I would think if it is a cracked head you would have bubbles in the radiator as the engine would be putting compression (air) into the cooling system. Possibly the water pump isnt circulating along with a bad temp gauge (guessing). Does the temp gauge move at all? Stuck thermostat...with a bad temp gauge. Would be an oddity but..... I dont think the 206 engines had problems with cracked head as the larger ones did. |
| Back to top |
JK2 Regular
Posted: Tue Oct 30, 2012 3:47 pm Post subject: Re: 445 steam from radiator |
It sounds to me like it could be that a new thermostat has been installed that has no bleed hole in it. Since the thermostat is in the hose a ways from the engine, if there is no bleed hole, the warm water can't get to it very quickly to make it open. I drill a 3/16" hole in the plate on new thermostats to prevent this. The original ones had this done when they were produced. |
| Back to top |
molinegb Long Time User
Posted: Tue Oct 30, 2012 4:30 pm Post subject: Re: 445 steam from radiator |
Anytime I have seen glowing exhaust it is a timing issue. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
