| Author |
Message |
selfsuffgrdnr New User
Posted: Tue Oct 30, 2012 9:55 am Post subject: Looking for implements and parts for Farmall A |
Hi. I'm new here. Just purchased a nice (in my opinion) Farmall A.
I'm now finding out that someone took off a lot of useful parts to make it into a parade tractor. I'm lacking the rear rockshaft (or whatever its called), master lift assembly package. Nothing to connect implements except a drawbar.
I'm trying to find these parts but in the meantime I'm also looking for a plow/disc to plow my front field for veggies. I figure I need a drawbar plow and I'll just rig up a loop bracket out of heavy steel and use a comealong to lift.
I could use some advice and guidance on how to do this and where to find implements.
Thanks!
Jason |
| Back to top |
gene bender Tractor Guru
Posted: Tue Oct 30, 2012 10:26 am Post subject: Re: Looking for implements and parts for Farmall A |
Rocksaft is not a part of the tractor but different rockshafts were used such as the one for the Cultivator and its not the samw as the one used for the Moldboard plow whether the plow was a single bottom or a two-way. Same thing for a middle buster a planter and the list goes on. There were two ways to lift the implements either a spring loaded lever or the Pneumatic Lift-All which used exhausst system for lifting all implements that were available for the A F armall. |
| Back to top |
Posted: Tue Oct 30, 2012 10:59 am Post subject: Re: Looking for implements and parts for Farmall A |
I have one row cult and also a veggie model that will do 2-4 rows Both are hand lift or exhaust lift |
| Back to top |
Posted: Tue Oct 30, 2012 11:36 am Post subject: Re: Looking for implements and parts for Farmall A |
| gene bender wrote: | | (quoted from post at 11:59:27 10/30/12) I have one row cult and also a veggie model that will do 2-4 rows Both are hand lift or exhaust lift |
Gene
Thanks for responding. Is the spring lift part of the implement or part of the tractor. I'll take a picture later today and post it. I understand how the implement connects to the drawbar but I can't see how it lifts. I'm new to this. Always used three points on Dad's farm.
Jason |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50401 Location: Lake of the Ozarks area of MO
Posted: Tue Oct 30, 2012 11:37 am Post subject: Re: Looking for implements and parts for Farmall A |
A lot depends on where you are. I am in Missouri and have a 1 bottom plow that is made to fit an A but shipping it much of any place will cost big time |
| Back to top |
Posted: Tue Oct 30, 2012 12:26 pm Post subject: Re: Looking for implements and parts for Farmall A |
Western Kentucky. Not too far away.
Jason |
| Back to top |
old Tractor Guru
Posted: Tue Oct 30, 2012 12:53 pm Post subject: Re: Looking for implements and parts for Farmall A |
I know I will never use this plow. I am at the Lake of the Ozarks area and my e-mail is always open |
| Back to top |
ken house Regular
Posted: Tue Oct 30, 2012 2:53 pm Post subject: Re: Looking for implements and parts for Farmall A |
some use A and Super A as one in the same tractor. does your tractor have hydraulics? if so super A. |
| Back to top |
Kevin Happke Regular
Posted: Tue Oct 30, 2012 5:46 pm Post subject: Re: Looking for implements and parts for Farmall A |
Hello Gene, Where are you located? What is the condition of the veggie cultivator....please call me at 320-468-6474 Thankyou |
| Back to top |
Posted: Wed Oct 31, 2012 12:48 am Post subject: Re: Looking for implements and parts for Farmall A |
Not on an A. |
| Back to top |
ncfarmer16 New User
Posted: Wed Oct 31, 2012 4:22 am Post subject: Re: Looking for implements and parts for Farmall A |
Ive got a Farmall A plow and some other parts. If your interested, send me a email |
| Back to top |
mkirsch Tractor Guru
Posted: Wed Oct 31, 2012 4:35 am Post subject: Re: Looking for implements and parts for Farmall A |
There is no "master lift" system for an A. Every implement has its own lift system, so if you don't get ALL the parts with a particular implement, it is useless. |
| Back to top |
mwilke Regular
Posted: Wed Oct 31, 2012 5:16 am Post subject: Re: Looking for implements and parts for Farmall A |
If you are willing to travel, try "JP Tractor Salvage" in Fredricktown, MO. They have quite an inventory of old Farmall stuff. |
| Back to top |
PretendFarmer Regular
Posted: Wed Oct 31, 2012 7:29 am Post subject: Re: Looking for implements and parts for Farmall A |
| selfsuffgrdnr wrote: | (quoted from post at 18:55:24 10/30/12) Hi. I'm new here. Just purchased a nice (in my opinion) Farmall A.
Thanks!
Jason |
I was in a similar situation as you. My 41 A came with a loader. Aside from that, just the draw bar. I have a few levers that bolt to the pads but I dont know what they go to, maybe a mower or something. I found a guy that wanted to sell the 16" plow with the lift and a snowplow setup all complete. I jumped on it.
If you can get the lift for the plow, its easy to fab up a 3 point hitch system. I am planning on doing that eventually. Then your options are endless...... |
| Back to top |
Posted: Wed Oct 31, 2012 8:07 am Post subject: Re: Looking for implements and parts for Farmall A |
| Back to top |
