| Author |
Message |
newoxford2-n New User
Posted: Tue Oct 30, 2012 1:27 pm Post subject: resistor |
I'm putting a 2-n front dist back together and I included a new resistor Several days ago I checked the voltage at the resistor and I had 6.3 going in and 2.3 coming out. Today I have 6.3 going in and 6.3 coming out. my question is was 2.3 coming out adequate? I guess I can assume the resistor is no good with 6.3 on both sides. If I did send 6.3 to the coil did I damage the coil? |
| Back to top |
JMOR Tractor Guru
Posted: Tue Oct 30, 2012 1:31 pm Post subject: Re: resistor |
| newoxford2-n wrote: | (quoted from post at 17:27:56 10/30/12)
I'm putting a 2-n front dist back together and I included a new resistor Several days ago I checked the voltage at the resistor and I had 6.3 going in and 2.3 coming out. Today I have 6.3 going in and 6.3 coming out. my question is was 2.3 coming out adequate? I guess I can assume the resistor is no good with 6.3 on both sides. If I did send 6.3 to the coil did I damage the coil? | Resistors drop NO voltage with NO current......you made the 6.3 in/6.3 out measurement with points open & the other with points closed. All is well. |
| Back to top |
newoxford 2-N Guest
Posted: Tue Oct 30, 2012 1:45 pm Post subject: Re: resistor |
Thanks. I know that, but my brain must have gotten caught up in the hurricane yesterday! |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Oct 30, 2012 1:46 pm Post subject: Re: resistor |
ditto what jmor said.
components devlop a voltage drop across them when current flows thru them. in an open circuit with no current flow ( points open ) no voltage drop.
All parts of a series circuit that is un grounded, will read supply volts.. assuming no blocking diodes or other silicon junctions inthe way..  |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
