Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Welding copper?
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
KIP in MX
PostPosted: Tue Oct 30, 2012 8:32 pm    Post subject: Welding copper? Reply to specific post Reply with quote
Anyone welded copper sheet? I want to make a copper tank/base for an Aladdin kerosene lamp from copper sheet and want to weld the seams. I have oxy/acetyline and Mig/Tig equipment. I don't want to use lead solder. Best advise?
casenut1
PostPosted: Tue Oct 30, 2012 9:01 pm    Post subject: Re: Welding copper? Reply to specific post Reply with quote
have never seen anything but solder on copper.
JDseller
PostPosted: Tue Oct 30, 2012 9:28 pm    Post subject: Re: Welding copper? Reply to specific post Reply with quote
Kip: Here is a link to a guy TIG welding copper. It is pretty neat. I had never seen it done before.
How to TIG Weld Copper Kevin Caron
Stick welding
PostPosted: Tue Oct 30, 2012 9:39 pm    Post subject: Re: Welding copper? Reply to specific post Reply with quote
TIG or silver solder will work. O/A might work but have never heard of it being used on copper. You might be able to find some info on the internet.
Puddles
PostPosted: Wed Oct 31, 2012 12:52 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
Interesting video! Until now I've never seen it done. Years ago when I worked as a weldor out of the sheet metal union I worked with several guys who had built copper hoods for commercial kitchen, the way they talked was just like the guy in the video, no big deal to Tig weld copper. I have also heard of using electrical wire, but also remember reading sometimes it can cause problems, but can't remember what! Embarassed
JOB
PostPosted: Wed Oct 31, 2012 12:57 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
He did not tell you that welding copper the way he did gives off fumes that are not good for you. You need good ventilation to weld copper.
timcasbolt
PostPosted: Wed Oct 31, 2012 3:16 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
He said it took 200 amps to get it going. That's a lot of heat!
Bus Driver
PostPosted: Wed Oct 31, 2012 3:41 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
I have brazed copper with oxy/acetylene. Works well. Never used TIG equipment. Interesting video.
casenut1
PostPosted: Wed Oct 31, 2012 5:02 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
that was 1/4 inch , looks easy. lets see it done with sheet copper , say 26 or 28 gauge. that's what i work with , bet it distorts all over the place.
JDseller
PostPosted: Wed Oct 31, 2012 5:30 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
Here is another video of a guy brassing copper, sheet,rods and lap joint.
brassing copper
Butch(OH)
PostPosted: Wed Oct 31, 2012 6:19 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
I have some bronze stick welding rod in the shop and it says it is good for copper.
cd1
PostPosted: Wed Oct 31, 2012 6:23 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
why not solder, it's easy, cheap and pretty strong.
greygoat
PostPosted: Wed Oct 31, 2012 7:51 am    Post subject: Re: Welding copper? Reply to specific post Reply with quote
Silver Solder, is it safe for food grade?
Stick welding
PostPosted: Wed Oct 31, 2012 9:23 pm    Post subject: Re: Welding copper? Reply to specific post Reply with quote
You can get cadmium free silver solder but check if it's rated for food service.
Bud in WV
PostPosted: Thu Nov 01, 2012 2:27 pm    Post subject: Re: Welding copper? Reply to specific post Reply with quote
I welded some copper buss bar and some copper nickle pipe years ago....it ain't pretty!
It takes a LOT of heat and it doesn't flow - at all! You can't "push" it with a TiG torch like steel, either. The "prettiest" Cu weld I've ever seen looked worse than a 2 hour beginner with a cold 7018.
Do yourself a big favor and solder it.
Goto page 1, 2  Next
Page 1 of 2
