| Author |
Message |
CraigChristian Regular
Posted: Wed Oct 31, 2012 1:40 pm Post subject: 2001 Husqvarna 350 Chainsaw ! |
I"ve had the 350 for about 10 years and have maybe used it 10 hours. I recently had to use it for the first time in a year and couldn"t get it started. I"ve done the routine maintenance stuff, but my problem now lies with the clutch cover. I made the mistake of removing it with the brake engaged. Now to put it back on, I need help figuring out how to deactivate the brake so it"ll slip back over the clutch. Thanks much, Craig |
| Back to top |
Sean Feeney Long Time User
Posted: Wed Oct 31, 2012 1:59 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
push handle all the way forward and it should reset release, you getting spark. check on / off switch |
| Back to top |
Posted: Wed Oct 31, 2012 2:16 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Thanks Sean, but the cover is already off. I somehow got it off with the brake engaged and now, of course, I don't know how to release the stainless loop so it'll slip over the clutch assembly. I see where the star wheel engages with the brake handle when it's assembled, but it's apart. Craig |
| Back to top |
55deere70 Regular
Joined: 24 Sep 2012 Posts: 253 Location: central Mass
Posted: Wed Oct 31, 2012 2:34 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Try positioning the handle so it engages with the star wheel when you put the clutch cover on, then you can release the chain brake. Or you can use a screwdriver or something to manually turn the star wheel back to release the brake. |
| Back to top |
ffinmich Regular
Posted: Wed Oct 31, 2012 3:18 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Look on you tube, there are instructions. Its a pain butit works. |
| Back to top |
TomH in PA Tractor Expert
Posted: Wed Oct 31, 2012 7:23 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Check the fuel line too. Mine cracks apart about every few hours of operation. |
| Back to top |
2x4 Tractor Expert
Posted: Wed Oct 31, 2012 7:34 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
about it not running, if you only rarely use it & you ran it last time with old gas, it might've ruined the cylinder & piston. The oil in old gas dissolves & no longer lubricates the engine & ruins it & will not start. For the chainbrake, the screwdriver trick of 55deere70 works for me. |
| Back to top |
Posted: Wed Oct 31, 2012 7:58 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Thanks Tom, it does leak a little gas. Is that a major job getting at it ?? I've never seen what is supposedly a quality product have more issues !! C |
| Back to top |
FredinMO Regular
Posted: Wed Oct 31, 2012 8:42 pm Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Take the plastic hand guard off 2 screws put yhe cover in the vice use the hand guard to unlock the chain brake reasemble. |
| Back to top |
Posted: Thu Nov 01, 2012 4:56 am Post subject: Re: 2001 Husqvarna 350 Chainsaw ! |
Thanks Fred - too easy !! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
