Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
CASE 1030
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
John LaBoyteaux
PostPosted: Thu Nov 01, 2012 2:59 am    Post subject: CASE 1030 Reply to specific post Reply with quote
So we removed and cleaned the 3pt control valve on our 1030. Arms will now raise (slowly) but will not remain in up position unless the engine is revved up. Pulling either of the remote valves (with nothing connected), the three point drops immediately even with the engine revved up. Any suggestions?
1031D
PostPosted: Thu Nov 01, 2012 8:23 am    Post subject: Re: CASE 1030 Reply to specific post Reply with quote
How is your oil level? Foamy? what kind of pressure does the pump put out? Sounds like either a cavitating pump or a leaking check valve.
John Saeli
PostPosted: Thu Nov 01, 2012 9:27 am    Post subject: Re: CASE 1030 Reply to specific post Reply with quote
Or a cracked housing, or blown seal on the piston.
Brokengun
PostPosted: Fri Nov 02, 2012 12:44 pm    Post subject: Re: CASE 1030 Reply to specific post Reply with quote
If you don’t mind I would like for you to answer some questions
Did the 3pt stop working all at once or did it happen over time?
[It is possible to bust the upper housing on a 30 series tractor that holds the cylinder for the 3pt if you had a heavy item on your 3pt and it was jarred harshly like crossing a ditch at high speed]
I also believe there is a seal on the end of your cylinder for the 3pt that can leak. Its also possible to have a really bad leak at the cylinder piston.
I think your problem could be the load check valve on the 3PT control valve.
My 930 diesel done about the same thing as you describe and I was able to cut the ball seat with a grinding stone and using a soft drift/punch re-seated a new ball.
I also suggest you do a pressure test at the remotes to see if they are working correctly.
Take a pressure gauge and screw on a male hydraulic tip and test the pressure on the outlet both sides and then let us know what you get.
I know you said you cleaned the 3Pt control valve. Did you change any settings and the adjustment screw on the plunger that rides on the ball that determines when the lift will drop?
[The plunger had what appears to be a bolt with a nut on the end used for locking it in place]
I know this is frustrating but it’s a problem that can be fixed.
The worse problem will be a cracked housing the least will be a worn load check valve.
Let us know what you find.
