| Author |
Message |
Fred from MO Long Time User
Posted: Thu Nov 01, 2012 9:58 am Post subject: How do you break the end of a moldboard? |
I posted the other day questions about a plow I have (new to me). It has 2 moldboards out of 3 where the trailing end of the moldboards are broken. How would this have happened. Is it common or was it from abuse? Middle moldboard is ok out of the 3 and the outer moldboards are busted. Sorry the shadow in the picture hides a little of what I was wanting to point out.
| Back to top |
Charlie M Long Time User
Posted: Thu Nov 01, 2012 10:32 am Post subject: Re: How do you break the end of a moldboard? |
Could have it a large rock. |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6406 Location: Delta,colorado
Posted: Thu Nov 01, 2012 10:38 am Post subject: Re: How do you break the end of a moldboard? |
Abuse.Someone simply backed into something or ran into it with some thing.If you have the pieces,you can repair them.When I was a kid,my father once 'tossed' a two bottom Ford plow from his pickup.It hit on the end of the moldboard-snapped like glass.Dad welded it back together and used it for several years. |
| Back to top |
paul Tractor Guru
Posted: Thu Nov 01, 2012 10:39 am Post subject: Re: How do you break the end of a moldboard? |
That is about the least stressed part of the molboard, so would be a very unusual thing to have happen in normal plowing? Unless the molboard is worn paper thin or something?
--->Paul |
| Back to top |
BTW,those look like IH Super Chief bottoms.They are still available... |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50398 Location: Lake of the Ozarks area of MO
Posted: Thu Nov 01, 2012 11:03 am Post subject: Re: How do you break the end of a moldboard? |
My dad did that to a plow I have. He hooked a chain around it to pull something and broke the mild board in half. Of course in this start it could well happen by hitting one of them small rocks you find once in a while |
| Back to top |
BCnT Tractor Expert
Posted: Thu Nov 01, 2012 11:20 am Post subject: Re: How do you break the end of a moldboard? |
my grandfather backed our Dearborn into a corner post when he was turning around...he had somebody weld it back in '65 or 66...i'm still using it. |
| Back to top |
rrlund Tractor Guru
Posted: Thu Nov 01, 2012 11:29 am Post subject: Re: How do you break the end of a moldboard? |
I saw a three bottom that had all of them broke that way at the sale in Archbold one time. Figured it had to have happened in transport on the way to the sale. They'd made some attempt to weld'em back on. |
| Back to top |
cumminspuller Long Time User
Posted: Thu Nov 01, 2012 12:03 pm Post subject: Re: How do you break the end of a moldboard? |
I just bought a 3/14 Deere trailer plow and the guy said he hit a tree at the end of the field with the number one mold board and broke off the outside part like yours is in the picture. |
| Back to top |
B-maniac Tractor Expert
Joined: 06 Jan 2006 Posts: 3086 Location: Mt. Pleasant , MI.
Posted: Thu Nov 01, 2012 2:33 pm Post subject: Re: How do you break the end of a moldboard? |
Most farmers did what they had to with what they had available. They had no "gators" , skidsteers , Quads or any of the "toys" most farmers have today. Tractors and equipment did a lot more than they were designed to do. Also a lot of very young drivers back then on tractors that were not very "youth freindly" if ya know what I mean. Crap happens when ya mix all that together. Lot of old machinery being pulled very carelessly out of tree rows/fence rows for scrap and then sold to someone to use/restore. Well , dammage done now. |
| Back to top |
Ol' Gimpy Regular
Posted: Thu Nov 01, 2012 3:18 pm Post subject: Re: How do you break the end of a moldboard? |
Looks like in the picture the moldboard brace is missing.Like the guys said,not uncommon to have these break from being hit,etc. The old cast parts were even more brittle,I"ve broken many a share from rocks back in the old days,when new shares were $6 each!! That should date them. |
| Back to top |
donjr Tractor Guru
Posted: Thu Nov 01, 2012 5:02 pm Post subject: Re: How do you break the end of a moldboard? |
Welll, ya takes a board, an spreads some mold on it, like from an ol bale of hay or the barnyard. Then ya goes down ta town an gets one of them little Krean felllers whut knows karatee, an get him to Whack it onct or twice. They kin usually break em reel easy...or do ya call that a moldy board???? |
| Back to top |
wolfman Tractor Expert
Posted: Thu Nov 01, 2012 5:28 pm Post subject: Re: How do you break the end of a moldboard? |
Probably got broken from back blow, not from plowing. I've plowed tough limestone clay with moldboard extensions and the boards would actually spring back without breakage - but don't back into a fencepost. |
| Back to top |
RodinNS Tractor Guru
Posted: Thu Nov 01, 2012 6:14 pm Post subject: Re: How do you break the end of a moldboard? |
You back into something....
Rod |
| Back to top |
Dean Olson Long Time User
Posted: Fri Nov 02, 2012 5:47 am Post subject: Re: How do you break the end of a moldboard? |
Probably abuse or not paying attention.
Years ago I picked up a C20 2pt fast hitch plow for my Farmall Super C. Really good shape. When unloading it my helper stayed on the joystick too long and the down pressure from the loader snapped the mold board in half. |
| Back to top |
