| Author |
Message |
Kenster Long Time User
Joined: 27 Jul 2006 Posts: 1004 Location: Bellville, TX
Posted: Thu Nov 01, 2012 10:00 am Post subject: Correct Bolt- Fan to Water pump 8N |
The book shows a 1/4 x 5/8- 28 thread bolt.
I need just one and, after looking at three stores can only
find half inch long and 3/4 inch long.
I bought one of each.
With an extra washer the 3/4 inch bolt should be just right.
OR the 1/2 inch bolt is exactly the right length without a washer.
Which way should I go? |
| Back to top |
carlntexas Regular
Posted: Thu Nov 01, 2012 10:25 am Post subject: Re: Correct Bolt- Fan to Water pump 8N |
I would cut the 3/4 of to the right length. |
| Back to top |
Mike Groom Long Time User
Posted: Thu Nov 01, 2012 10:55 am Post subject: Re: Correct Bolt- Fan to Water pump 8N |
Hacksaw a couple of threads of and file the end. |
| Back to top |
Dean Tractor Guru
Thread a nut onto the longer bolt, cut to proper length, chamfer the end on a grinder and remove the nut to chase the threads.
Dean |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50659 Location: Lake of the Ozarks area of MO
Posted: Thu Nov 01, 2012 11:08 am Post subject: Re: Correct Bolt- Fan to Water pump 8N |
As Dean says put a nut on the bolt clamp it in a vise so the nut is right where you need to cut it off at so you have a mark to go by cut it off and work the nut off part of the way and back on a couple times to clean up the tread and then install it. Easy as pie |
| Back to top |
souNdguy Tractor Guru
Posted: Thu Nov 01, 2012 11:30 am Post subject: Re: Correct Bolt- Fan to Water pump 8N |
ditto.. size the 3/4 to 5/8 and clean that first thread.. |
| Back to top |
Posted: Thu Nov 01, 2012 12:39 pm Post subject: Re: Correct Bolt- Fan to Water pump 8N |
| soundguy wrote: | | (quoted from post at 15:30:57 11/01/12) ditto.. size the 3/4 to 5/8 and clean that first thread.. |
I found plenty of clearance between the back side of that bolt plate and the belt pulley groove. I could probably have gone with another half inch longer bolt if necessary.
Cheers! |
| Back to top |
Bob Harvey Tractor Guru
Posted: Fri Nov 02, 2012 3:06 pm Post subject: Re: Correct Bolt- Fan to Water pump 8N |
" one of each" WOW! What if using the one new one throws the sucker out of balance?? Just pushing your chain. b |
| Back to top |
Posted: Fri Nov 02, 2012 3:09 pm Post subject: Re: Correct Bolt- Fan to Water pump 8N |
" one of each" WOW! What if using the one new one throws the sucker out of balance?? Just pushing your chain. I have a habit of replacing every bolt I take off with SS and a 'smidge' of never seize, costs VERY little extra and if there is a next guy he will appreciate it- looks cool also. b |
| Back to top |
Posted: Fri Nov 02, 2012 3:12 pm Post subject: Re: Correct Bolt- Fan to Water pump 8N |
Oops, got distracted. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
