Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
TD9 IH
Post new topic    Yesterday's Tractors Forum Index -> Crawlers, Dozers, Loaders and Backhoes
Case Nutty 1660
PostPosted: Thu Nov 01, 2012 10:17 am    Post subject: TD9 IH Reply to specific post Reply with quote
guy's I just picked up a fairly nice TD9 crawler and am rounding up a sevice manual for it, my question is the RH steering clutch will not release ( I can feel the brake will work if the clutch would release) and the lever does not take much to pull it back like the left clutch that does work correctly, I have a feeling it will need a tear down to fix can any one give me a few ideas what could be wrong and how bad are they to get to? thanks for any info as I am not familar with the IH units,,,,yet lol thanks again cnt
gemdozer
PostPosted: Thu Nov 01, 2012 1:10 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
You could try adjusted the stering cluch first and the adjustement is make by turning the turncbukle at the end stering cluch lever and you need 4" free movement at top lever and you should have 3" free movement on top brake pedal and the adjustement is under the housing from the inspection cover
Case Nutty 1660
PostPosted: Thu Nov 01, 2012 1:38 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
Thanks for the info, I did adjust the steering lever and now I have the same resisitance on both levers but the RH hand still will not release, maybe stuck from sitting? I do know that it would not steer when they parked it some 20 years ago, I am hoping it can be worked on from the top cover and I do not have to remove final drives ect to get to the steering clutch cnt
JimInOz
PostPosted: Thu Nov 01, 2012 2:13 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
CN,
Good news is that clutches are accesssed thru the top,under the seat.
There has been lots of discussion on clutches over on the REDPOWER site.You can get new bi-metalic discs now,if you need to replace them.They help to prevent bonding up.
Check the condition of the clutch release forks when you go in there.
Jim
Case Nutty 1660
PostPosted: Thu Nov 01, 2012 2:23 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
thank you Jim, I take it this is some what a common problem? cnt
gemdozer
PostPosted: Thu Nov 01, 2012 3:34 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
You do't need to removed the final drive for working on stering cluchs
Darald in Sk
PostPosted: Thu Nov 01, 2012 9:27 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
Try General Gear and Machine in Boise, Idaho. Very helpful people. webmaster@tractorparts.com
PD Mechanical
PostPosted: Fri Nov 02, 2012 4:05 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
Am very familiar with the IH brand. The 9 clutches are a bit of a pain. Very little room to get at a few of the bolts and many are lock wired. Also....be sure to put index marks on the pinion flange and brake drum because there is only one way to get "all" the bolts back in. I have discs, hard parts and free information available if you need them. Good Luck. Steve. www.pdmechanical.com
Case Nutty 1660
PostPosted: Fri Nov 02, 2012 5:19 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
Thank guy's for the info I will let you know how it goes and be in contact for needwed parts cnt tom
Dennis K (WA)
PostPosted: Fri Nov 02, 2012 7:34 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
I would suggest removing the winch. You'll be glad it is out of your way by the time you are done. Also I believe there are long tie bolts going throught the steer clutch compartment that help hold the winch on. They will have to be removed for clutch removal.
Steering clutches freezing up is fairly common when the machines sit and moisture is present. Best to use them once in awhile.
Have fun
Dennis
TomA
PostPosted: Fri Nov 02, 2012 7:54 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
I have a method that may no be approved of by all.
I would run the tractor back and forth while riding the brake to heat up the drum real good. Then short hard stabs on the brake while holding the clutch back may break it free.
Case Nutty 1660
PostPosted: Fri Nov 02, 2012 10:32 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
certainly worth a try thanks cnt
Case Nutty 1660
PostPosted: Fri Nov 02, 2012 10:40 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
the sticking may be from what you describe as this unit was mainly used to move snow on a steep canyon road so a lot of down time is sure in the cards, I have not gotten a ops manual yet but when I do I will do a service on it and see where water is hiding sure would be nice if it would come loose with out total disassembly but will do what it takes as it seems to be a fairly good dozer with not a huge amount of hours or wear thanks again for any input, IH dozers are not in my knowleage at all but am willing to learn cnt
Case Nutty 1660
PostPosted: Fri Nov 02, 2012 11:46 am    Post subject: Re: TD9 IH Reply to specific post Reply with quote
Success!!! went back and fired the ole girl up and drove her about 25' rearward working clutch and brake a few times, then drove forward 10' or so doing the same and when I pulled back on the steering clutch I thought I felt it release on the RH side stepped on the brake and she turned like it should thanks to all and TomA too for all sugeestions and offers of help I will be doing a full service on her soon to get her ready for winter thank you all again very much cnt tom
Dennis K (WA)
PostPosted: Fri Nov 02, 2012 4:09 pm    Post subject: Re: TD9 IH Reply to specific post Reply with quote
great fix and the price was right also.
Dennis
