Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Farmall 240 Decal Placement - Help Needed.
Farmallhal
PostPosted: Thu Nov 01, 2012 2:21 pm    Post subject: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
I am about to start putting my 1958 Farmall 240 back together and have been thinking of an issue I will be coming up against in a couple of months. I can't find any documentation as to the decal location like is provided in Guy Fay's Originality Guide for the Farmall Letter Series tractors. I believe I have the best and complete set of decals available but have been unable to find anything useful as to their original factory locations. Bermuda Ken of CNG has offered to look into some original IHC blueprints for possible location data for the uncommon ones which are rarely seen so he might be providing something as well. Thanks for any assistance anyone can provide, Hal.
Mark Peters
PostPosted: Thu Nov 01, 2012 3:03 pm    Post subject: Re: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
Hal, I went out to the shed this afternoon and took these pics of the decal placement on my 587 actual hours Farmall 240 . These are original decals to the best of my knowledge. I bought this tractor from the original owners` son and he stated it was never touched as far as repainting goes ( I redid the white skirting a few years back because it was peeling , showing bare metal and I didn`t want it to rust). Hope this helps. P.S. Per your phone call, Wittek tower hose clamps on it too.
Radiator decal
Oil filter
Patent Decal on side of seat base
Battery Cover (Don`t turn at high speeds)
Air Cleaner
Light switch
Hitch to drawbar only (rear of seat base)
PTO shield
Farmall 240
Farmallhal
PostPosted: Thu Nov 01, 2012 4:05 pm    Post subject: Re: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
Thanks Mark for the informative response with the pictures. I have two decals left that still need a home. One states "CAUTION - 6 volt electrical system" and the other "CAUTION - Stop engine before opening this cap (followed with a pointing arrow to something)" I think the latter could be linked to the Hydra-Touch system filler plug but that is just a guess. Neither the 240 Operators or Preventive Maintenance Manuals contains a caution about opening the filler plug with the engine running though. Thanks again for your assistance, Hal.
Bob zarse
PostPosted: Fri Nov 02, 2012 11:20 am    Post subject: Re: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
The stop engine goes right where you said. Right side of engine pointing to the oil filler cap. It is really hard to get this stick on. The caution 6 volt goes by the plug by you back lite.
Farmallhal
PostPosted: Sat Nov 03, 2012 12:26 pm    Post subject: Re: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
Bob, thank you very much for the info and after looking at my tractor this morning I see excatly where it goes. I guess the 6 volt decal isn't needed since I don't have the electrical break-away connector on the rear fender.
Mark Peters
PostPosted: Sat Nov 03, 2012 2:28 pm    Post subject: Re: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
farmallhal wrote:
(quoted from post at 16:26:32 11/03/12) I guess the 6 volt decal isn't needed since I don't have the electrical break-away connector on the rear fender.
Hal, Now that Bob jogged my memory , about the 6 volt decal going to the breakaway connector, that`s gotta be right. I have a couple NOS lights that plug into the breakaway connector and they have a 6 V decal on the light housing too. The connectors must have been an option. My F340 has one, but not my F240. I also took some more pics that you requested of the tachometer cable clips and gas line routing. The tach cable comes out on left side of tractor, then crosses to right side behind the engine. Good luck ! Mark
Tach cable clip on left side of tractor
Tach cable on right side of tractor
Gas line
Farmallhal
PostPosted: Sat Nov 03, 2012 4:20 pm    Post subject: Re: Farmall 240 Decal Placement - Help Needed. Reply to specific post Reply with quote
Mark, as always thanks for the pictures and now I have a clear understanding of how to route the tach cable. Looks like I need to install the carb and air cleaner and mock-up a piece of brake line for a new fuel line. I'll probably start with a solid piece of copper to get correct routing and bend the tubing to match with a hand bender. I'm not ready to install the fuel tank yet so that will have to wait a little while but now I have the pictures. Thanks again, Hal.
