| Author |
Message |
btaft Guest
Posted: Thu Nov 01, 2012 3:10 pm Post subject: cracked block |
Hello, I have a massey harris 44 engine with a visable crack between cylinders. What are my options with this problem and what are the costs with any of the solutions. Thanks |
| Back to top |
Goldsburg Regular
Posted: Thu Nov 01, 2012 5:29 pm Post subject: Re: cracked block |
It has been my experience that many blocks are cracked between either 3 and 4 or 1 and 2 in stock form. "Usually" these cracks do not cause issues.
If you have experience with this block that these cracks are a problem, there is the option to braze them up and re-machine the deck. This process could run in the $400 to $500 range, but finding another "good" block may be in that price range anyway.
Regards,
Goldsburg |
| Back to top |
grs0820 Regular
Posted: Fri Nov 02, 2012 2:37 am Post subject: Re: cracked block |
Is the crack at the top or the bottom??? at the top the head gasket will seal the issue. at the bottom is another story. I have seen putting sealant in the crack and taking a stainless steel rod through the block and pulling it together. Fact is stranger than George Jones.... |
| Back to top |
Massey44puller Guest
Posted: Sun Nov 18, 2012 6:00 pm Post subject: Re: cracked block |
Metal Locking Service Inc. in Buffalo may be an option if your "in the neighborhood". They cut a french fry shaped hole across the crack (perpendicular) and then peen a high strength piece into the hole to lock it together. There is more to the process and it is not cheap, but it is very strong. I had them do a j382 block about six years ago. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
